dagerman
Sep 14, 2015Aspirant
ReadyNAS NV+ will not complete booting
Hi there, I need some guidance, please. My trusted ReadyNAS NV+, which has worked flawlessly for the better part of 8 years has decided it's time to take a break. It disappeared from the network, R...
dagerman
Thanks so much for responding, "mdgm".
I am aware that tech support mode is not intended for end users. Alas, I was so far unsuccessful to reach support and given the fact that the device is long out of warranty and I have not found a for-fee support option, I have to try to use the crowdsourcing approach to get my device working again. It appears to be my only option.
I do appreciate your words of caution; I am equipped with 30 years of (IT) experience about not thinking before typing and have learned the hard way to try and avoid it... ;)
I did start the RAID manually and mounted /dev/hdc on /sysroot, sorry for leaving that part out of my original post.
I did some more digging around today and it appears that disk #2 does not have a valid partion table. Compared to #2, the other three disks show a seemingly valid and similar partition structure (fdisk -l).
So I have ordered a supported replacement hard drive and will see if that gets me past the boot issue.
I am not sure where the OS partition resides, but none of the visible partions had less than 30% free disk space (as reported by df -h).
It is entirely possible that my email notification stopped working at some point due to moving and email provider changes; I am pretty sure I never updated settings in Frontview. So, I may have missed the early indications of impeding disk failure that have allowed me proactive disk swaps in the past. I'll make sure to rectify that if I can get this device back to work. It has been one of the most reliable pieces of tech in my arsenal by far.
Again, I am grateful for your comments and will update this thread with my findings once I receive my replacement drive. Thank you!
Stefan
mdgm-ntgr
Sep 15, 2015NETGEAR Employee Retired
On a Sparc NAS a disk not having a partition table is normal if using X-RAID. It is the dedicated parity disk and it is normal for it not to have the partition table on it.
You must have started out with just one or two disks.
If you have mounted the 2GB OS partition on /sysroot you can check how full it is easily using commands such as:
# /sysroot/bin/df -h # /sysroot/bin/df -i
# /sysroot/usr/bin/du -csh /sysroot/*
# /sysroot/usr/bin/du -csh /sysroot/var/*
# /sysroot/usr/bin/du -csh /sysroot/var/log/*
- StephenBSep 15, 2015Guru - Experienced User
Did you try booting up the NAS with only 3 disks? (removing each disk in turn). Of course be careful to remove/replace disks with the NAS powered off.
Sometimes a single failed disk will prevent booting, and it is an easy thing to try.
- mdgm-ntgrSep 15, 2015NETGEAR Employee Retired
The get_ata_errors command will tell you how many ATA errors there are for each disk. This might give an indication as to which disk has failed if one has.
True. I wasn't meaning to say the OP shouldn't gather that information.
Just that the 3-drive tests might be worth running too.
- dagermanSep 15, 2015Aspirant
# ./get_ata_errors /dev/hdc 540 # ./get_ata_errors /dev/hde 0 # ./get_ata_errors /dev/hdg 0 # ./get_ata_errors /dev/hdi 0 # /sysroot/bin/df -h Filesystem Size Used Avail Use% Mounted on rootfs 7.7M 6.5M 1.3M 83% / /dev/root 7.7M 6.5M 1.3M 83% / tmpfs 16k 0 16k 0% /dev/shm /dev/hdc1 1.9G 322M 1.6G 17% /sysroot # /sysroot/bin/df -i Filesystem Inodes IUsed IFree IUse% Mounted on rootfs 2048 248 1800 13% / /dev/root 2048 248 1800 13% / tmpfs 7070 1 7069 1% /dev/shm /dev/hdc1 256000 11112 244888 5% /sysroot # /sysroot/usr/bin/du -csh /sysroot 289M /sysroot 289M total # /sysroot/usr/bin/du -csh /sysroot/var 44M /sysroot/var 44M total # /sysroot/usr/bin/du -csh /sysroot/var/log 16M /sysroot/var/log 16M total
It appears that /dev/hdc has quite a few errors (540). Do the device names map to drive bays in sequence, i.e. hdc=bay1, hde=bay2, etc?
Also, are the listed free space numbers concerning at all?
Really appreciate your help!
