AV8THOR
Oct 14, 2016Aspirant
ReadyNAS NV+ Won't power on after powering down
Model - ReadyNAS NV+ RND4210 (Note -original label on chassis says RND4000 V3 over which a sticker has been placed saying RND4210) Not sure of firmware version. Unit was shut down and disconnected whi...
Oct 14, 2016Guru - Experienced User
First of all, you have an NV+ v1 (sparc-based ReadyNAS). The RND4000 is the chassis/diskless part number.
The RND4210 is an RND4000 that shipped with factory-installed disks. The "x2xx" means it shipped with 2 disks, the "xx1x" means those disks were 1 TB each.
If the serial number of your NAS is between 000DA2010FFE and 000DA2016000, then there was a service action, and you are entitled to a replacement PSU even if the NAS is out of warranty. Otherwise, the normal warranty (usually 5 years on your NAS) would apply.
There are some replacement supplies out there, but they are generally expensive. You can also get a less expensive generic supply, but you do need to modify the pinout before you install it.
AV8THOR
Thanks for the great feedback StephenB. Serial number is 23JXXXXXXXXXX. Thanks again.
- JennCOct 14, 2016NETGEAR Employee Retired
Hello AV8THOR,
Please try contacting support and see they can arrange an RMA for your PSU. However, there is a fee for the replacement.
Welcome to the community!
- JennCOct 17, 2016NETGEAR Employee Retired
Hello AV8THOR,
Have you tried calling in already?
Regards,- AV8THOROct 18, 2016Aspirant
I have called in, and was informed that Netgear has decided to abandon its customers and that failed NV+ power supplies are not being replaced.
However I can feel free to BUY a replacement power supply.
- JennCOct 18, 2016NETGEAR Employee Retired
Hello AV8THOR,
Can you PM me the SN of the NAS or the case number they gave you?
