AV8THOR
Oct 14, 2016Aspirant
ReadyNAS NV+ Won't power on after powering down
Model - ReadyNAS NV+ RND4210 (Note -original label on chassis says RND4000 V3 over which a sticker has been placed saying RND4210) Not sure of firmware version. Unit was shut down and disconnected whi...
thjh_ikon
Feb 01, 2017Aspirant
I've just encountered the same problem.
I have 3 NV+ units. My building is undergoing some electrical system maintenance and is shutting down power at night. In order to avoid potential problems, I shut down all 3 appliances even though they are attached to UPS. The units shut down without issue.
However, 2 of the 3 will not power on any more.
Is this really a power supply issue? It seems strange that 2 units would experience this at the same time and this would happen from simply powering off.
- StephenBFeb 02, 2017Guru - Experienced User
Try removing the disks (labeling by slot). The units normally will power up in that state (and RAIDar will report "no disks").
If they don't power on, the most likely cause is the PSU. Though a failed system board could also present the same symptoms.
- thjh_ikonFeb 04, 2017Aspirant
Thank you StephenB. I'll give that a try. Luckily, the arrays contain mostly redundant data and I have one NV+ left that is still working for the time being and I can use it to retrieve the data.
If the devices do power on without disks, can I simply start re-inserting the disks?
- SandsharkFeb 04, 2017Sensei
Did you also disconnect the NASes from power? Even when they are off, the 5V standby power is on, and that's used to command the NAS on. In my NVX that needed a new supply (same supply as NV+), it was the standby power that was at fault.
I don't think it's a good idea to insert the drives one by one unless you are willing to lose the data on them. You don't want it deciding that it needs to re-build the array when you have a known issue. Besides, just because you can insert them one at a time (spinning up independently) doesn't necessarily mean it has the necessary power to spin them up all at once, if the power supply is the issue.
You could put all drives in your other NAS though, to see that one of them is not the culpret. If the problem moves with the drives, you'll need to figure out which one it is. A USB dock and manufacturer's diagnostic software is the best first step there.
Since you have another NV+, you could swap the power supply from it to see if that's the issue. It sounds to me like it probably is, but that would save you buying a replacement supply only to find that's not the problem. There is a chance that, if something else within the NAS "took down" the supply, it could do the same to the other one, but it realy doesn't sound like that's the case here.
