Lestrad's avatar
Lestrad
ReadyNAS nv+ won't power up after outage. Power Supply Problems?
Hello My ReadyNAS NV+ (Product: ReadyNASRND4000, Serial Number: 23J3027700C11) was originally purchased in November 2010. In June 2016 I had a problem with the power supply: The NAS wouldn't start u...
  • Sandshark's avatar
    Sandshark
    Jul 09, 2019
    Yup.  You can test that it turns on the supply with it disconnected before you do it with it connected.  You'll know the supply came on because the fan will run.
    If it works, you likely won't want to leave it that way, but it's a way to get the data off the NAS.
ProSupport for Business
