bertschj
Aug 15, 2017Aspirant
ReadyNAS NV+ Won't Power Up
Hello - My NV+ will not power up. PS not smoked - just no power. Reseated RAM also - no change. Saw several threads regarding defective PS - my serial falls within range - 000D-A201-837E. Cal...
- Aug 15, 2017
Hello bertschj,
I'm sorry but this unit is very old that Netgear no longer manufactures even its PSU.
You might be able to find a someone who sells ReadyNAs NV+v1 power supply on the Internet. The part number is RND4PSU1-10000S.
Welcome to the community!
JennC
Aug 15, 2017NETGEAR Employee Retired
Hello bertschj,
- bertschjAug 15, 2017Aspirant
Thanks Jenn
Is this possible?
"is it possible to use PS from NV+/RND4410v3 unit? "
- JennCAug 15, 2017NETGEAR Employee Retired
Hello bertschj,
RND4410v3 is probably a Sparc-based NAS too. Can you PM me the SN? I will try to check if I can identify if it is Sparc-based which is the same as the v1.
I used the power supply from the RDN4410 and it works fine in the RDN4000.
