bertschj
Aug 15, 2017Aspirant
ReadyNAS NV+ Won't Power Up
Hello - My NV+ will not power up. PS not smoked - just no power. Reseated RAM also - no change. Saw several threads regarding defective PS - my serial falls within range - 000D-A201-837E. Cal...
- Aug 15, 2017
Hello bertschj,
I'm sorry but this unit is very old that Netgear no longer manufactures even its PSU.
You might be able to find a someone who sells ReadyNAs NV+v1 power supply on the Internet. The part number is RND4PSU1-10000S.
Welcome to the community!
JennC
Aug 15, 2017NETGEAR Employee Retired
Hello bertschj,
bertschj
Thanks Jenn
Is this possible?
"is it possible to use PS from NV+/RND4410v3 unit? "
- JennCAug 15, 2017NETGEAR Employee Retired
Hello bertschj,
RND4410v3 is probably a Sparc-based NAS too. Can you PM me the SN? I will try to check if I can identify if it is Sparc-based which is the same as the v1.
- bertschjAug 15, 2017Aspirant
I used the power supply from the RDN4410 and it works fine in the RDN4000.
- JennCAug 16, 2017NETGEAR Employee Retired
Hello bertschj,
If that is the case, then I am glad you were able to make it work. I strongly suggest to always have an updated backup of the data.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
