RickLevenson
Jun 13, 2025Aspirant
ReadyNAS NV+ won't power up
Yes, I know this is very old but I am hoping... I have replaced the power supply and the on-board battery and there is still no life to it. At this point, I really just want to get the data off the...
- Jun 14, 2025
There is a pin-out mod needed for the NV+
There are some supplies that have been pre-modified - did you get one of those?
If not, details are here:
RickLevenson wrote:
At this point, I really just want to get the data off the 4x 1T drives but I don't know how to do that short of getting it powered back up.
You could connect the drives to a Windows PC using a 4-bay USB enclosure (no need for hardware RAID, and that can get in the way). Then use R-Studio to offload the data.
It looks like all versions support EXT, LVM, and RAID (which is what you need).
Jun 14, 2025Guru - Experienced User
RickLevenson wrote:I have replaced the power supply
RickLevenson wrote:At this point, I really just want to get the data off the 4x 1T drives but I don't know how to do that short of getting it powered back up.
- RickLevensonJun 14, 2025Aspirant
This is incredibly helpful and I suspect is the issue, since it is a stock power supply. I'll work on it later today. Thank you!!!
Let me know of a favorite charity. If this works, I'll make a donation in your honor. I love the wisdom of the network.
- RickLevensonJun 25, 2025Aspirant
Winner winner, chicken dinner. This was exactly the issue. Thank you thank you thank you!
Since you haven't responded, I'll make the donation to The United Way, since that is generally viewed as positive by everyone.
- StephenBJun 25, 2025Guru - Experienced User
That of course is fine. Or your local food pantry.
