wildwood's avatar
wildwood
ReadyNAS NV+V2 Problems With Disk Failure + Disk Unrecoverable Errors
The unit is a ReadyNAS NV+V2 (RND4000) fitted with 4 x 3TB Seagate Barracuda ST3000DM001 Disks in a Flex-RAID (Raid 5) volume, it runs RAIDiator 5.3.11 and is powered through an APC UPS. Usage is aro...
  • wildwood's avatar
    wildwood
    Feb 15, 2017
    Thanks for the response.
    I've managed to get the bits of data that weren't already backed up off the array and as per your suggestion am going to build a new array using WD Red drives.
    Thanks again for your feedback.
ProSupport for Business
