yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
yoicks
I think I spoke too soon about VMFS v5... Even with VMFS v5 it isn't working as it goes to 100% but hangs there during vm creation and times out with the error: "A general system error occurred: The system returned an error. Communication with the virtual machine might have been interrupted"
And on the server:
2011-08-27T17:15:57.480Z cpu4:2052)NMP: nmp_ThrottleLogForDevice:2318: Cmd 0x93 (0x41240077ac40) to dev "naa.60014052e2962c00248d005000000000" on path "vmhba34:C0:T2:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.Act:NONE
2011-08-27T17:15:57.504Z cpu6:2054)ScsiDeviceIO: 2305: Cmd(0x41240077ac40) 0x93, CmdSN 0x37f to dev "naa.60014052e2962c00248d005000000000" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.
2011-08-27T17:15:57.509Z cpu6:2054)ScsiDeviceIO: 2305: Cmd(0x41240077ac40) 0x93, CmdSN 0x37f to dev "naa.60014052e2962c00248d005000000000" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.
2011-08-27T17:15:57.529Z cpu6:2054)NMP: nmp_ThrottleLogForDevice:2318: Cmd 0x93 (0x41240077ac40) to dev "naa.60014052e2962c00248d005000000000" on path "vmhba34:C0:T2:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0xb 0x24 0x0.Act:NONE
2011-08-27T17:15:57.533Z cpu6:2054)ScsiDeviceIO: 2316: Cmd(0x41240077ac40) 0x93, CmdSN 0x37f to dev "naa.60014052e2962c00248d005000000000" failed H:0x3 D:0x0 P:0x0 Possible sense data: 0xb 0x24 0x0.
2011-08-27T17:15:57.533Z cpu6:2054)ScsiDeviceIO: 2949: CmdSN 0x3a8 to device naa.60014052e2962c00248d005000000000 timed out: expiry time occurs 0ms in the past
2011-08-27T17:15:57.533Z cpu2:3069)FS3DM: 2427: status Timeout zeroing 1 extents (8192 each)
2011-08-27T17:15:57.533Z cpu2:3069)J3: 2601: Aborting txn (0x410018c26330) callerID: 0xc1d00006 due to failure pre-committing: Timeout
2011-08-27T17:15:57.533Z cpu2:3069)Fil3: 13341: Max timeout retries exceeded for caller Fil3_FileIO (status 'Timeout')
2011-08-27T17:15:57.533Z cpu2:3069)BC: 4347: Failed to flush 1 buffers of size 8192 each for object 'ccc.vmx' f530 28 3 4e59095c 17ec0508 898cf726 94e818a5 1809944 9 0 0 0 0 0: Timeout
So in other words, ReadyNAS NVX isn't usable with ESXi 5.0 at all from my tests.
And on the server:
