yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
mdgm-ntgr
Aug 27, 2011NETGEAR Employee Retired
What version of RAIDiator are you running?
RAIDiator 4.2.19 (currently in public beta) is due for production release soon and it would be good if you could check once that's released if you still have issues using that.
Welcome to the forum!
