yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
mdgm-ntgr
Aug 28, 2011NETGEAR Employee Retired
I guess it could be a little while then before the issue is resolved. An update may require a fair bit of testing. Especially when it comes to be business applications, stability is important. Also they won't want to break other uses of iSCSI in addressing compatibility with ESXi 5. Personally I wouldn't expect this to be resolved in 4.2.19, but then I'm just a user making a guess so I could be wrong.
