yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
beisser1
Aug 29, 2011Tutor
i have a similar issue in my lab with esxi5.0 and a readynas pro running 4.2.18. with nfs everything works. when i try iscsi i get all kinds of weird issues including the one described here.
my system.log shows this:
Aug 29 16:13:31 ESX-ISCSI kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
Aug 29 16:14:02 ESX-ISCSI last message repeated 8768 times
Aug 29 16:14:32 ESX-ISCSI last message repeated 8642 times
can you check your system.log if it shows similar entries?
