yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
DAPBENJAMIN
Sep 02, 2011Aspirant
Don't blame you.... It is trivial to reproduce. QNAP did it about 1 hour after I opened a case with them!
Take ReadyNAS (tons of those lying around) install ESXi connect using iSCSI bang....
