yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
grinks
Sep 06, 2011Aspirant
Not sure if you guys have looked or not, but as of now all of the ReadyNAS products are not on the Hardware Compatability Listing for vSphere 5.0 4.1 U1 is the highest release. I would also make sure you have checked your server hardware to ensure it is on the list as well.
I have included a link to the HCL below.
http://www.vmware.com/resources/compatibility/search.php
