yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
pain2k
Sep 06, 2011Aspirant
If you follow VMware and their HCL for some time, you will see, that it will take some time until all systems are evaluated again.
It's on Netgear to recertify the ReadyNAS line for 5.0 again, as VMware has not enough ressources to recertify all HW on the HCL
by themself.
So - Netgear - hurry up!
BTW: Updated to 4.2.19 and still not working! Waiting for 4.2.20....
by themself.
