yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
yoicks
Sep 08, 2011Aspirant
@chirpa The problem still exists with me as well. I have emailed the logs to you so you can have a look.
If you require any further information please let me know.
Thanks,
Thanks,
