yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
mdgm-ntgr
Sep 09, 2011NETGEAR Employee Retired
This is a good example of why it's a bad idea to rush to adopt a major new version of software/a operating system in a production environment. Large businesses can setup test environments whereas smaller companies can use the web (e.g. forums like this) to check for issues that arise which early adopters discover.
