yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
Rygar4
Sep 22, 2011Aspirant
chirpa wrote: Tried the beta firmware? http://www.readynas.com/forum/viewtopic.php?f=51&t=57193
So far everything is working with new firmware... did some vmotion and created a new Virtual with no problems.
Thank you!!! :neener:
