yoicks
Aug 27, 2011Aspirant
ReadyNAS NVX problems with ESXi 5.0 [Case #16549549]
Hello, I'm trying out ESXi 5.0 with iSCSI on ReadyNAS NVX but it seems that it is not able to write to the volume VMFS v3.46, which it should be able to. I can add the target perfectly fine and the...
beisser1
Jan 08, 2012Tutor
until the final 4.2.20 firmware is released you need to use the current beta if you want to use esxi5. no way around that except if you like to wait :)
