SlyB
May 27, 2019Aspirant
readynas nvx rndx4210 not recognised by RAIDar
Hi, I have got used readynas nvx rndx4210. Done the factory reset, NAS took the IP from DHCP, I can see it in the LAN as well as it's default share folders. The problem is, I can't get to the m...
- May 27, 2019
SlyB wrote:
Tried to follow Netgear's instructions from here: https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
You don't have an OS-6 system, so you shouldn't be using those instructions.
SlyB wrote:
The problem is, I can't get to the management interface of it.
What happens when you browse to https://nas-ip-address/admin
May 27, 2019Guru - Experienced User
SlyB
May 28, 2019Aspirant
What happens when you browse to https://nas-ip-address/admin?
When I browse to that address, I login straight to the management console of the NAS :-D.
Damn, that was easy.
Thanks a lot for your help!
Sly
