SlyB
May 27, 2019Aspirant
readynas nvx rndx4210 not recognised by RAIDar
Hi, I have got used readynas nvx rndx4210. Done the factory reset, NAS took the IP from DHCP, I can see it in the LAN as well as it's default share folders. The problem is, I can't get to the m...
- May 27, 2019
SlyB wrote:
Tried to follow Netgear's instructions from here: https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
You don't have an OS-6 system, so you shouldn't be using those instructions.
SlyB wrote:
The problem is, I can't get to the management interface of it.
What happens when you browse to https://nas-ip-address/admin
Sandshark
May 27, 2019Sensei
And to further empahsize, you also don't have a system that can be updated to OS6. If you try using the OS4.2 to OS6 upgrade instructions, you'll brick the NAS. The NVX is a 32-bit system and OS6 only runs on 64-bit systems. But the upgrade process won't warn you of that (it assumes you've read the instructions).
And since you have an older OS4.2 system,. you also don't have ReadyCloud to discover the NAS in that way ot to use it for remote access.
SlyB
May 28, 2019Aspirant
Thanks Sandshard, good tips!
