carpii
Dec 03, 2016Tutor
ReadyNAS NVX wont power up
I was replacing my UPS with a more powerful one, so shut down all three of my ReadyNAS (2 Pro 4's and an NVX). But after doing this, the NVX will not power on (The 2 Pro 4's are fine). I believe ...
Sandshark
Dec 03, 2016Sensei
Or, for a cheaper option, with a bit more effort from you, see here: Inexpensive power supply replacement for legacy 4-bay Readynases. And, BTW, it is much more common for the power supply to fail on a power-up than when running continuously.
