jbernardo
Jul 14, 2021Apprentice
Readynas OS 6.10.5 breaks admin interface
Hi, My readynas was working well, with 6.10.4 hotfix 1. I accepted the prompt to update to 6.10.5, and now I can't connect to it - I always get the error " This site can’t be reached readynas refu...
- Jul 15, 2021
I fixed the issue finally by using acme.sh and installing a letsencrypt certificate. I'll post a guide on how to do it as I couldn't find any updated one for the readynas.
Sandshark
Jul 14, 2021Sensei
Is it possible that your OS partition is full or nearly so? That can cause a lot of hard to diagnose errors caused by corrupt configuration files, especially when doing an OS update or re-install, which take additional space.
- jbernardoJul 14, 2021Apprentice
The OS partition only has 29% used, so that shouldn't be an issue.
The used and available space on my system:
# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 3.7G 1005M 2.5G 29% / tmpfs 249M 0 249M 0% /dev/shm tmpfs 249M 392K 248M 1% /run tmpfs 125M 1.3M 123M 2% /run/lock tmpfs 249M 0 249M 0% /sys/fs/cgroup /dev/md127 2.8T 2.2T 581G 80% /data /dev/md127 2.8T 2.2T 581G 80% /apps /dev/md127 2.8T 2.2T 581G 80% /home
Anything I can do other than a factory reset? I do have an external drive with an rsync of /data as a backup (which I just updated), but I'd rather not risk wiping and restoring. And I don't look forward to configuring the different shares I have again...
- mdgmJul 14, 2021Virtuoso
You have an ARM system so you need to check for inode usage on the 4GB root volume as well:
# df -i
- jbernardoJul 15, 2021Apprentice
I've posted twice but my reply keeps getting deleted, no idea why and no notification.
But what I put was the output of "df -i" showing that the root device had only 2% of the inodes used.
I've tried launching apache2 again, and systemD gives an out of space error, but no idea which device it is complaining of. None show as full on "df" and "df -i".
