aleksey_bobrov
Jul 06, 2021Aspirant
ReadyNAS OS 6.10.5. Connect to Admin page for a few second, after: "Connecting to the ReadyNAS Admin
Hello. NetGear RN10200 ReadyNAS OS 6.10.5 Problem: connects to the admin page for only a few seconds, then the message: "Connecting to the ReadyNAS Admin Page" The system is fully operation...
- Jul 07, 2021
StephenB wrote:
StephenB wrote:
There is apparently a hot-fix out there, but I don't think it's being pushed through the Netgear update servers just yet.Sandshark has reported that he's gotten the hotfix, so it is being pushed now.
aleksey_bobrov: you might just try rebooting your NAS, and see if it picks up the hotfix.
Thank you. I installed hotfix and it works
Jul 06, 2021Guru - Experienced User
aleksey_bobrov wrote:
NetGear RN10200
ReadyNAS OS 6.10.5
Lots of people have already reported this.
Try using Chrome, and enter https://nas-ip-address/admin (using the real NAS IP address). The https bit is important.
- aleksey_bobrovJul 06, 2021Aspirant
thanks, I'll try
NetGear RN10200
ReadyNAS OS 6.10.5
Problem: connects to the admin page for only a few seconds, then the message: "Connecting to the ReadyNAS Admin Page"Lots of people have already reported this.
NetGear RN10200
ReadyNAS OS 6.10.5
I tried, unfortunately, the same thing- StephenBJul 06, 2021Guru - Experienced User
StephenB wrote:Try using Chrome, and enter https://nas-ip-address/admin (using the real NAS IP address). The https bit is important.
You can also try an OS reinstall from the front panel (don't do a factory default) Instructions start on page 20 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
That will change the admin password back to password, which should let you log in. It will change a couple of other settings
- The network will be set back to the default setting (DHCP)
- Volume quota (on the volume settings wheel) will be turned off.
You can then downgrade back to 6.10.3 or 6.10.4 (before you change the password).
- SandsharkJul 06, 2021Sensei
The hotfix is going live. My sandbox NAS now shows it's at 6.10.5 Hotfix 1. But since it never had the problem, I can't say if this fixes it.
