Retired_Member
Jul 08, 2018ReadyNAS OS 6.9.3 fail (again)
I just updated from OS 6.9.2 to the latest OS 6.9.3 and found the NAS lost most of the Apps in the store (only 3 available apps in the store now?).
- GLPI (0.84.8+dfsg,1-1)
- PlexPy
-Shell in a...
- Retired_MemberJul 10, 2018
'apt-get upgrade' fixed the app store issue
Marc_V
Jul 08, 2018NETGEAR Employee Retired
Hi Retired_Member
Have you tried going to https://www.plex.tv/downloads/ and downloading the version for your NAS and try reinstalling? the same with the 2 other apps you mentioned.
If you can send in the logs we might be able to check.
Regards
