Retired_Member
Jul 08, 2018ReadyNAS OS 6.9.3 fail (again)
I just updated from OS 6.9.2 to the latest OS 6.9.3 and found the NAS lost most of the Apps in the store (only 3 available apps in the store now?).
- GLPI (0.84.8+dfsg,1-1)
- PlexPy
-Shell in a...
- Retired_MemberJul 10, 2018
'apt-get upgrade' fixed the app store issue
Retired_Member
Jul 08, 2018I can upload apps from https://apps.readynas.com/pages/ but the admin page still only lists 3 apps to install from (I installed Shell in a Box from this page, but the WebGUI/Admin Page didn't recognize the install, yet I can URL to it fine):
ReadyNAS OS 6.9.3 Listed Apps
Shouldn't I be seeing more apps?
StephenB - I only listed the folder to show the varied permissions via shell (su to root shows the same folders+ permissions). The Web Admin page i beleive still requires admin login (can't login as root via WebGUI page)?
Retired_Member
Jul 08, 2018Shell in a Box installed, NAS re-started ok, but still shows Shell in a Box as un-installed (Shell in a Box works though via direct URL). This is the same for all 3 apps listed.
- mdgm-ntgrJul 08, 2018NETGEAR Employee Retired
What do you see if you do
# dpkg -l(note that's a lower case L at the end of the line above).
- Retired_MemberJul 09, 2018
I see over 500 packages listed most in ii status. I've msg'd u the list
- mdgm-ntgrJul 09, 2018NETGEAR Employee Retired
ii readynasos 6.9.3 all ReadyNASOS base system
Looks like your NAS can’t download packages from the internet. That package should be at 6.9.3+3
If you set a static I.P. address on the NAS a common mistake is to notify specify any DNS Server Addresses.
