Retired_Member
Jul 08, 2018ReadyNAS OS 6.9.3 fail (again)
I just updated from OS 6.9.2 to the latest OS 6.9.3 and found the NAS lost most of the Apps in the store (only 3 available apps in the store now?).
- GLPI (0.84.8+dfsg,1-1)
- PlexPy
-Shell in a...
- Retired_MemberJul 10, 2018
'apt-get upgrade' fixed the app store issue
Retired_Member
Jul 09, 2018connect is fine now - ping/tracert is working (dns now working)
I had some router resetting issues before, so I f/reset the router and forgot about some old IP references (possibly during the NAS f/w update).
Should I just rollback to OS6.9.2 then re-update?
I had a quick look through the logs....may be easier if I just f/reset the f/w (retain data) and just setup the box again
Retired_Member
Jul 10, 2018'apt-get upgrade' fixed the app store issue
- StephenBJul 10, 2018Guru - Experienced User
That is a bit risky, and can break stuff. apt-get update is a safer option.
- Retired_MemberJul 14, 2018
yea I noticed some didn't get upgraded (selected not to over-ride the different defaults). seems to be ok for now (I can always just OS f/reset if required)
