DCA-IT
Dec 12, 2019Aspirant
ReadyNAS OS Rsync job permissions incorrect
We've set up a DR Rsync job to copy data on NAS1 to NAS2. We'd like to have the job running weekly but when the job runs, it copies the data but creates a completely bizzare (and very incorrect) set ...
Dec 12, 2019Guru - Experienced User
Of course there are no NTFS permissions involved (since the NAS doesn't use the NTFS file system).
Have you looked at the btrfs file permissions with ssh?
DCA-IT
Hi Stephen, thanks for your response.
What are the permissions I'm seeing when I browse to the shared folder (or any of the sub-folders) in Windows Explorer and view Properties > Security > Advanced? These don't match anything I can see when I connect to the NAS via the web console and look at the permissions set there in Network Access or File Access.
I cannot seem to connect to the NAS using SSH. When I enter the credentials in Putty, the window simply vanishes. SSH is deinately enabled on the NAS though...
