DCA-IT
Dec 12, 2019Aspirant
ReadyNAS OS Rsync job permissions incorrect
We've set up a DR Rsync job to copy data on NAS1 to NAS2. We'd like to have the job running weekly but when the job runs, it copies the data but creates a completely bizzare (and very incorrect) set ...
Dec 12, 2019Guru - Experienced User
Of course there are no NTFS permissions involved (since the NAS doesn't use the NTFS file system).
Have you looked at the btrfs file permissions with ssh?
DCA-IT
I've managed to connect Putty using SSH now. What commands would I use to view the permissions?
- DCA-ITDec 12, 2019Aspirant
I'm trying the command below to browse to the directory I want to check permissions on but when I enter the path, I get an error saying "No such file or directory exists".
cd /<share name>/
The directory does very much exist. I can browse to it and open files. For some reason, the command line will not see it.
Sussed it...
btrfs permissions on the subject share are:
drwxrwx---+ 1 administrator domain admins 172 Oct 30 07:56 <directory>
Sub-folders are the same.
I've attached a screenshot of what I can see in Windows Explorer. The highlighted yellow items should not be there and the two red boxes are duplicates.
