Yoda1492
Jan 24, 2021Luminary
ReadyNAS Pioneer Pro BUG: Unable to handle kernel null pointer dereference at (null)
Hello, I have not been using my ReadyNAS Pioneer Pro because I have four other Netgear NASs and this NAS has been problematic in the past. Since the NV+ can not be upgraded to OS 6, I decided to re...
Jan 24, 2021Guru - Experienced User
How much memory do you have in the NAS?
Also, do you have any apps installed?
Yoda1492
Hello Stephen,
Thanks for quick reply! There are no apps installed on this NAS as I just use the NAS to RSYNC data from the other NASs. It was also just factory reset within the week so it only has on it what you get from that.
As for memory, I never added any memory. It came with 1 DIMM in the NAS. The DIMM is a 1GB DIMM. The memory tests pass that you do through the hardware via the boot menu.
- Labdoc1Jan 24, 2021Luminary
FWIW, I had the same experience with my ProPioneer over the past year. It has os 6.10.4. From time to time, without any entry in the logs or warning, no apps and temperatures OK, it behaves as you describe. I replaced it with a used RN526x. The ProPioneer is now #2 backup to the RN526. (#1 backup is USB that goes offsite regularly).
- Yoda1492Jan 24, 2021Luminary
Hello Labdoc1,
Thanks for the reply. It is good to know that I am not alone with this issue with this model of hardware! With this issue I would never trust it to store any data that I did not have elsewhere. If the issue can not be resolved, I will use the NAS for parts as I have three other working Netgear NASs and one retired Netgear NV+. The NAS does hold six drives and does load/run the latest OS. If the NVRAM can be replaced, I would be willing to do that if people thought that would help. I will leave this issue open for a bit to get any ideas that people think might help. The link above shows the testing that I had done before with this issue. Have a great day.
- StephenBJan 24, 2021Guru - Experienced User
I'd try removing the bond, and I'd also disable ipv6 if that is enabled.
No idea if that will help, but neither are actually needed, and it's easy to try them.
I disabled IPv6.
I also disabled the ReadyDLNA service as I do not need that.
I left the bond configured for now as I do not want to make too many changes at one.
I rebooted and it rebooted fine. I then shut it down, waited a minute, powered it on, and it booted fine. It is after poweron from the poweroff state that the issue happens (minus the one time of it just dropping off the network after being left on all night - that had never happened before). I will do several poweron tests and if the NAS still has the issue, I will break the network bond. I could also test with just one network cable. However, I recall the issue happening even when no network cable was attached. I will report back after several poweron tests.
- SandsharkJan 24, 2021Sensei
The NAS will say "ReadyNAS" if there is nothing present except +5V, so a lot can be wrong. Your best bet is to acquire a VGA cable to connect to the VGA header in the unit and see if you see anything going on during boot that could explain it.
If you just want to take some stabs at it, the first thing is to get more RAM. Others have reported problems with 6.10.x on legacy systems with only 1GB of RAM. Since all Intel based native OS6 NAS come with at least 2GB, Netgear is not going to be checking that it'll work in 1GB. Since bad RAM could also be it and DDR2 RAM is so cheap these days, replacing the existing DIMM at the same time might also help.
Another real possibility is a failing power supply. If you have a spare ATX supply, you can install that externally and see if it fixes the issue. Since it takes a while to see if it's really fixed, you'll want to use masking tape to fill the gap where the cable comes out and cover the power supply fan opening so the chassis fan draws air over the drives. You may need a SATA to 4-pin Molex power adapter or 4-pin Molex splitter to make it work.
