Yoda1492
Jan 24, 2021Luminary
ReadyNAS Pioneer Pro BUG: Unable to handle kernel null pointer dereference at (null)
Hello, I have not been using my ReadyNAS Pioneer Pro because I have four other Netgear NASs and this NAS has been problematic in the past. Since the NV+ can not be upgraded to OS 6, I decided to re...
Yoda1492
Hello Stephen,
Thanks for quick reply! There are no apps installed on this NAS as I just use the NAS to RSYNC data from the other NASs. It was also just factory reset within the week so it only has on it what you get from that.
As for memory, I never added any memory. It came with 1 DIMM in the NAS. The DIMM is a 1GB DIMM. The memory tests pass that you do through the hardware via the boot menu.
Labdoc1
FWIW, I had the same experience with my ProPioneer over the past year. It has os 6.10.4. From time to time, without any entry in the logs or warning, no apps and temperatures OK, it behaves as you describe. I replaced it with a used RN526x. The ProPioneer is now #2 backup to the RN526. (#1 backup is USB that goes offsite regularly).
- Yoda1492Jan 24, 2021Luminary
Hello Labdoc1,
Thanks for the reply. It is good to know that I am not alone with this issue with this model of hardware! With this issue I would never trust it to store any data that I did not have elsewhere. If the issue can not be resolved, I will use the NAS for parts as I have three other working Netgear NASs and one retired Netgear NV+. The NAS does hold six drives and does load/run the latest OS. If the NVRAM can be replaced, I would be willing to do that if people thought that would help. I will leave this issue open for a bit to get any ideas that people think might help. The link above shows the testing that I had done before with this issue. Have a great day.
