Kalessin
Apr 23, 2015Initiate
ReadyNAS Pro 4 — ERR: Could not properly extract [Resolved]
I started a factory default boot to reset all my settings and wipe the disks. When I next looked at the LCD on the front of the device, it was showing: ReadyNAS Pro 4 wrote: ERR: Could not ...
- Apr 23, 2015Just a man.
Glad I could help.
mdgm-ntgr
Apr 23, 2015NETGEAR Employee Retired
Just a man.
Glad I could help.
Glad I could help.
- bcurran3Oct 14, 2015Aspirant
I too have this exact problem. I'm staring at ERR: Could not p Create C: right now.
Could someone please share with me the magical fix that doesn't seem to be posted publically?
- PavolDec 10, 2015Tutor
It looks like there are multiple people facing this same problem, including myself. Could someone please post the solution? Thanks.
- StephenBDec 10, 2015Guru - Experienced User
Usually when mdgm does a PM he is arranging to do some remote troubleshooting.
More than likely your flash is corrupted. If you are the original purchaser, paid Netgear support is one way forward. Trying to fix it yourself could do more damage.
