Squazz
May 24, 2013Aspirant
ReadyNAS Pro 4 - Volume Scan Failed
Hi there
I have a ReadyNAS Pro 4 with RAIDiator 4.2.23 that won't "boot".
When the NAS starts, the systems starts, but when I visit the admin page, I'm promted with the message "Volume Scan Failed..."
Yesterday I was trying to configure my config file for BT Sync, but I constantly got the errormessage that there wasn't enough space on the destination (And I have/had about 40% free of my 6Tb)
What can I do, have I completely lost all of my data now?
Volume:
3x WD RED 3Tb, all less than 3 months old
Installed AddOns
PlexMediaServer
ReadyNAS Remote
ReadyNAS Photos II
Futhermore I have installed CrashPlan & BT Sync on the device
Edit:
When looking ad my logs, I found this:
Fri May 24 11:04:26 CEST 2013 Volume scan failed to run properly.
Fri May 24 11:02:29 CEST 2013 Volume scan failed to run properly.
Fri May 24 08:03:09 CEST 2013 System is up.
Fri May 24 08:01:34 CEST 2013 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
Fri May 24 08:01:34 CEST 2013 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 3]
Fri May 24 08:01:34 CEST 2013 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2]
Thu May 23 21:08:36 CEST 2013 System is up.
This, really doesn't seem all that nice for me :/ Especially because I had-rebootet the device at about 3am because the system halted.
Volume:
Installed AddOns
PlexMediaServer
ReadyNAS Remote
ReadyNAS Photos II
Edit:
- mdgm-ntgrNETGEAR Employee RetiredSounds like you didn't configure either BT Sync or CrashPlan correctly and you've filled your 4GB OS partition. This can lead to all kinds of problems. I suggest you open a tech support case (see Online Submission link in my sig) and see if there is anything that they can do to help. Please post your case number.
- SquazzAspirant
mdgm wrote: Sounds like you didn't configure either BT Sync or CrashPlan correctly and you've filled your 4GB OS partition. This can lead to all kinds of problems. I suggest you open a tech support case (see Online Submission link in my sig) and see if there is anything that they can do to help. Please post your case number.
Ok, will do, thanks :) I really hope that I havn't lost my data :(
