dave1234
Dec 26, 2017Aspirant
ReadyNAS Pro 4 Firmware Install
I forgot my password, and the manual says I can reset the username and password without losing data by reinstalling firmware. I have the firmware downloaded, but don't know how to install it. The d...
JohnCM_S
Dec 26, 2017NETGEAR Employee Retired
Hi dave1234,
To re-install the OS and reset the password to default, you will need to access the boot menu and select the OS re-install. You may check this link for the procedure on how to do the OS re-install.
JohnCM_S
NETGEAR Community Team
dave1234
That worked great!
Thank you so much!
Dave
