Ken_C1
Oct 21, 2014Aspirant
ReadyNAS Pro 4 fsck failing
I've got a ReadyNAS Pro 4 (recent rma for an NVX). When I installed the drives from the NVX in it, it booted just fine. I elected to upgrade it to 4.2.27 (or whatever the latest one is). After tha...
Oct 21, 2014Guru - Experienced User
My guess is that something actually is corrupted in the file system. So rsyncing the data to another device is a good first step. Of course it might fail when it gets to whatever files are at the 64% point.
After that you could continue to repair the file system, or do a factory reset and rebuild from scratch.
