Ken_C1
Oct 21, 2014Aspirant
ReadyNAS Pro 4 fsck failing
I've got a ReadyNAS Pro 4 (recent rma for an NVX). When I installed the drives from the NVX in it, it booted just fine. I elected to upgrade it to 4.2.27 (or whatever the latest one is). After tha...
mdgm-ntgr
Oct 21, 2014NETGEAR Employee Retired
Definitely sounds like big issues with the filesystem.
If you can't backup your data you may wish to consider paid support options.
