BlazeAxtrius
Aug 15, 2016Aspirant
ReadyNas Pro 4 website and PHP(enablerootssh)
Hello everyone, I am new here. I have a ReadNas Pro 4 X-Raid2 and I am trying to setup a website with PHP. I followed a couple of tutorials and I managed to make a website folder and actuall...
mdgm-ntgr
Aug 15, 2016NETGEAR Employee Retired
Installing the add-on from RNXtras is the way to go.
Did you configure the options you want in the settings for the add-on.
Perhaps the ownership/permissions of your php script are not set correctly.
I don't think I would recommend using a Pro 4 as a public webserver at this point. The current firmware 4.2.28 was released October last year.
- StephenBAug 15, 2016Guru - Experienced User
Good point. Since Netgear announced that there would be no more firmware updates, security vulnerabilities will grow over time.
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
There will actually be a 4.2.29 released soon, so things may be O.K. for a little while. I expect 4.2.29 will be the final release.
- BlazeAxtriusAug 16, 2016Aspirant
I am not sure what options or permission I can change. I haven't configure anything in the PHP, I just installed it and that is it.
