jcoomans
Jul 02, 2016Aspirant
ReadyNAS Pro 4 X-RAID2 with 4 Drives not rebuilding array after Drive 3 Failure
Recently, my ReadyNAS Pro 4 had a Hard Drive that failed in Drive 3. Since I am using X-RAID2, my volume is now running unprotected. I purchased a spare, hot-swappable drive and replaced it, but my R...
DaneA
Jul 03, 2016NETGEAR Employee Retired
Hi jcoomans,
Try to connect the new drive to a PC then format it to NTFS format. Afterwards, insert it again to bay 3 of your ReadyNAS Pro 4 then observe if it will rebuild the volume automatically when inserted.
DaneA
NETGEAR Community Team
Jul 03, 2016Guru - Experienced User
I suggest rebooting the NAS first. If the status doesn't change, then remove the drive (NAS running) and hot-insert it. Be very careful to remove/reinsert the correct drive.
If that fails, then try the PC formatting.
- jcoomansJul 05, 2016Aspirant
Tried hot-swapping and then restarting. No effect. I'll try formatting now.
- jcoomansJul 09, 2016Aspirant
Hmmm. . .I followed your advice, pulled the new drive, and used my PC to successfully format it as NTFS. Re-inserted the drive, saw that it was detected and tested, and then got the same message that the volume would be rebuilt with Drive 3, but nothing happens. Rebooted, and same result, "volume will be rebuilt with Drive 3," but nothing happens.
- StephenBJul 09, 2016Guru - Experienced User
Perhaps hover the mouse over the green disk circles (either in RAIDar or on the nas admin UI), and see if it gives you more status.
You might need support's help on this.
Yeah. . .I was aware of the what the green disk circles display, but no dice. The volume is not being rebuilt. I am on the phone with tech support, but they have determined that this is a "software issue," so I had to fork over $75 for a one-time case. We'll see what happens, but I'm on the second engineer so far. I'll update this forum after I get the results. I've been on the phone for an hour and 09 minutes, and no one has even gotten into the unit yet.
Not. Impressed. At. All.
Especially when paying for support on a hardware issue that should be covered under warranty.
