jcoomans
Jul 02, 2016Aspirant
ReadyNAS Pro 4 X-RAID2 with 4 Drives not rebuilding array after Drive 3 Failure
Recently, my ReadyNAS Pro 4 had a Hard Drive that failed in Drive 3. Since I am using X-RAID2, my volume is now running unprotected. I purchased a spare, hot-swappable drive and replaced it, but my R...
jcoomans
Jul 09, 2016Aspirant
Hmmm. . .I followed your advice, pulled the new drive, and used my PC to successfully format it as NTFS. Re-inserted the drive, saw that it was detected and tested, and then got the same message that the volume would be rebuilt with Drive 3, but nothing happens. Rebooted, and same result, "volume will be rebuilt with Drive 3," but nothing happens.
Jul 09, 2016Guru - Experienced User
Perhaps hover the mouse over the green disk circles (either in RAIDar or on the nas admin UI), and see if it gives you more status.
You might need support's help on this.
- jcoomansJul 09, 2016Aspirant
Yeah. . .I was aware of the what the green disk circles display, but no dice. The volume is not being rebuilt. I am on the phone with tech support, but they have determined that this is a "software issue," so I had to fork over $75 for a one-time case. We'll see what happens, but I'm on the second engineer so far. I'll update this forum after I get the results. I've been on the phone for an hour and 09 minutes, and no one has even gotten into the unit yet.
Not. Impressed. At. All.
Especially when paying for support on a hardware issue that should be covered under warranty.
- StephenBJul 09, 2016Guru - Experienced User
To clarify, I don't work for Netgear.
jcoomans wrote:
Especially when paying for support on a hardware issue that should be covered under warranty.I've been told that if that turns out to be the case the fee is refunded.
- jcoomansJul 10, 2016Aspirant
I know you don't work for Netgear ;) Thanks for the attempt to help, I appreciate it.
I set up remote access, and they are supposed to contact me 24-48 hours after enabling it (which means sometime today or tomorrow at the latest). I'll be they claim it is a software issue, but we'll see.
I'll update this post when I know more.
