Retired_Member
May 30, 2016ReadyNAS Pro 6 – lost admin password
I started to do the Netgear MyNETGEAR single sign-on account migration (one ring account) and after doing the update I went to my NAS to upgrade to 6.5 (current 6.4.1). The password I had for admin ...
- Jun 01, 2016
Hi kiddude,
The OS reinstall procedure only resets the administrator password and IP settings, to defaults. Just ensure that it will be done correctly.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
May 30, 2016NETGEAR Employee Retired
Hi kiddude,
Try other web browsers or different browser mode like 'incognito' and 'private' browsing. If it still won't work, the last thing you can do is to perform OS reinstall.
Kind regards,
BrianL
- Retired_MemberJun 01, 2016
No luck with the different browers or modes. It looks like an OS reinstall. One question. Is an OS reinstalla complete wipe of the system and I need to pull everything off or can it be done without inpact on the data?
- BrianL2Jun 01, 2016NETGEAR Employee Retired
Hi kiddude,
Kind regards,
BrianL
NETGEAR Community Team- Retired_MemberJun 01, 2016
Hi Brian,
Thanks for the feedback so far. I did find the instructions online (included for future reference):
http://kb.netgear.com/app/answers/detail/a_id/21107
Only thing is this PRO 6 is running OS 6.4.1. The documentation reads that this going to pull the firmware from the internal flash to the disks but wouldn't that going back to 4.x.x firmware so it would be incompatable?
Karl
