AndyWheatcroft
Apr 21, 2019Aspirant
ReadyNAS Pro 6 - Disk showing "dead" even though bay is empty
ReadyNAS Pro 6 - Running RAIDiator 4.2.31 - X-RAID2
5 x 3TB - Seagate ST33000650NS - Dual Redundancy
Disks installed in bays 1 thru 5
Whilst running my monthly data scrubbing, disk in Bay 1 di...
Apr 21, 2019Guru - Experienced User
AndyWheatcroft wrote:
I doubt that I am really in degraded mode
Not sure myself.
Can you download the log zip file, and post mdstat.log and mdconfig.log?
- AndyWheatcroftApr 21, 2019Aspirant
Had to covert files to PDF. Looking at this file, it is obvious that the RNP thinks I only have 4 working disks yet Frontview shows different.
- StephenBApr 22, 2019Guru - Experienced User
You can just copy/paste text snippets from the logs.
mdstat shows the system is somewhat confused.
- md1 and md4 are using all disks (including the missing/dead one)
- md0 and md3 are using the missing/dead disk, but not the new one
- Only md2 is correct.
This could probably fixed with ssh (or by paid support). Another approach is just do a factory reset, and restore the NAS from backup.
- AndyWheatcroftApr 22, 2019Aspirant
Hi Stephen,
I am happy to try fixing with SSH. If that fails I can always do a factory reset but it will take a long time to resore everything due to only having USB2 speeds.
Can you tell me what I should modify?
File "/proc/mdstat" is a zero length file but when I type "cat mdstat" it shows what is in the log file. And if I try "vi mdstat", i get a new file.
Thanks,
Andy.
