stubbsy1
Oct 11, 2014Guide
Readynas Pro 6 - no display, How to factory reset?
I have a ReadyNas Pro 6. Some time ago the display stopped working (pressing the backup button does nothing, nor does it display during boot). Up until now this hasn't been a big deal, but now I want ...
vandermerwe
Oct 12, 2014Master
Your pro 6 should be under warranty , have you contacted support?
I think your plan to use the boot menu on the working unit to guide you should work.
