G1DDO
Feb 08, 2019Aspirant
ReadyNas Pro 6 - To Be Filled in by OEM
Can anyone help me I have updated the OSfrom 4 to 6 which all worked fine and was running then for some reason the boot was corrupted possibly when upnplugged but not sure.
I was getting the MB...
- Feb 13, 2019
Hi G1DDO,
The fix has been applied already and it should display now the correct serial number. The NAS was rebooted into Normal mode as well.
schumaku
Feb 08, 2019Guru - Experienced User
Reads like OS 4 had stored or retrieved this information from a different resource - OS 6 does apparently use DMI to read the SMBIOS - and your machine (or model) does not have this information set in place during the manufacturing process. No idea if this is intended or not - some more experienced old crows have to folow up.
- mdgmFeb 08, 2019VirtuosoThis output suggests that the EEPROM data has been wiped off the internal flash. This is a common side effect of USB Boot Recovery on systems that shipped with RAIDiator-x86 4.2.x such as your system.
- G1DDOFeb 08, 2019Aspirant
Yes I suspect so however weirdly im pretty sure it did work after the upgrade as it changed the model to business pro.
That aside is there anyway of putting this data back ?
- JohnCM_SFeb 13, 2019NETGEAR Employee Retired
Hi G1DDO,
