G1DDO
Feb 08, 2019Aspirant
ReadyNas Pro 6 - To Be Filled in by OEM
Can anyone help me I have updated the OSfrom 4 to 6 which all worked fine and was running then for some reason the boot was corrupted possibly when upnplugged but not sure.
I was getting the MB...
- Feb 13, 2019
Hi G1DDO,
The fix has been applied already and it should display now the correct serial number. The NAS was rebooted into Normal mode as well.
mdgm
Feb 08, 2019Virtuoso
This output suggests that the EEPROM data has been wiped off the internal flash. This is a common side effect of USB Boot Recovery on systems that shipped with RAIDiator-x86 4.2.x such as your system.
G1DDO
Yes I suspect so however weirdly im pretty sure it did work after the upgrade as it changed the model to business pro.
That aside is there anyway of putting this data back ?
- JohnCM_SFeb 13, 2019NETGEAR Employee Retired
Hi G1DDO,
- G1DDOFeb 14, 2019Aspirant
Awesome works perfectly now, just added some shares and ISCSi, just need to add some new drives.
Many thanks for this.
Neil
