Pete_C
Feb 07, 2016Tutor
ReadyNAS Pro 6 Checking root FS
Hi, I have a small issue with my ReadyNAS Pro 6 running OS6.4.0. Until recently it has been runnning fine. However, when the unit was booted up yesterday it shows the squares for each of the six...
- Feb 09, 2016
It's all,sorted with huge thanks to mdgm who has reinstalled the OS on the unit.
OSBuckeyes4Life
Feb 23, 2016Tutor
I do now. My NAS froze for no reason again last night. I had to hard power it off and came back up normal.
- mdgm-ntgrFeb 23, 2016NETGEAR Employee Retired
Looks like you've got quite a lot of apps on this unit. Do you still run into this problem if you disable the apps?
- OSBuckeyes4LifeFeb 26, 2016Tutor
i have never tried that as i did not know 4 apps was a lot. it is curently frozen right now, i can see the ip on the front screen and it shows all drives, but RAIDar does not see it and nothing is loading webpage wise for it. If i hard reset it like last time it comes right up but this keeps happening.
