Pete_C
Feb 07, 2016Tutor
ReadyNAS Pro 6 Checking root FS
Hi, I have a small issue with my ReadyNAS Pro 6 running OS6.4.0. Until recently it has been runnning fine. However, when the unit was booted up yesterday it shows the squares for each of the six...
- Feb 09, 2016
It's all,sorted with huge thanks to mdgm who has reinstalled the OS on the unit.
masammut
Mar 16, 2016Aspirant
Thank you mdgm. Readynas is working fine now. But I noticed that it only found one LAN port now. Before I had the 2 LAN ports in teaming mode. Any tips to to get the other LAN port back?
Thanks again
Mark
Thanks again
Mark
- mdgm-ntgrMar 16, 2016NETGEAR Employee Retired
So it can only see the one NIC?
Have you tried clearing your web browser cache, closing your web browser then reopening the web admin page?
You would need to setup teaming again.
- masammutMar 17, 2016Aspirant
Ok - So removing and replacing ethernet cables and a couple of reboots and both NICs are being detected and so a new LACP bond was created successfully.
However all of sudden now, the system fan is at 0 RPM and an error is naturally coming up every couple of minutes. I'm not sure if the system is overheating, but something is not right. Any ideas?
Also the Status is saying that the "System is Dead" maybe could be related to the System fan though.
System Fan issue also solved by moving the system fan cable to the unused connector on the IO card.
System is Healthy now and working perfectly - thanks especially to mdgm who took the time to remote into my system to fix the Root FS issue.
