smar
Aug 08, 2018Tutor
ReadyNAS Pro 6 Checking root FS
Hi
My ReadyNAS Pro 6, running firmware 6.7.5 was working fine for many months. However, a few days ago, it became inaccessible from web gui and ssh (did not reply to pings) and appeared hung. A...
- Aug 08, 2018
Yes that's possible. It should only be considered though if confident that the disks are healthy (you've checked SMART stats) and that the data volume RAID and filesystem are in a good state.
Formatting the root volume wipes the logs etc. off it.
After trying to mount md0 you should check what the error message is by doing e.g.
# dmesg | tail
Depending on what the error is it might be fixable (with a small amount of data loss) without resorting to the drastic step of formatting md0. Greater care needs to be taken with the data volume if that fails to mount.
A read-only btrfsck can provide useful information.
mdgm-ntgr
Aug 08, 2018NETGEAR Employee Retired
# dmesg | tail
- smarAug 09, 2018Tutor
Thanks mdgm. Your PM was also very helpful. I've sent another PM with a small query on which I would be grateful for your input on.
