tony359
Mar 30, 2023Apprentice
ReadyNAS Pro 6 crashed again
Hello all, My ReadyNAS Pro6 periodically stops responding to the network. When that happens I can push the button to shutdown it but it will sit on "shutting down" forever and then I'll have to p...
tony359
Jun 12, 2023Apprentice
The NICs are on two different IP range - one main network, one PC only.
What used to be on main network is now directly connected to the PC and what used to be connected to the PC is now connected to the main network and I've swapped the IP addresses accordingly.
I did that yesterday and I've just checked: NAS has disappeared. Sigh!
I SSH'd through the other NIC, restarted it and it worked as usual.
So
- It's not the specific NIC
- It's not the switch
It's curious that it's always the NIC on the main network failing and not the other.
Help 🙂
schumaku
Jun 12, 2023Guru - Experienced User
As you are in the lucky situation having an alternate LAN interface (and IP subnet) available. what does the kernel output show when the device "disappeared", ...?
# dmesg
The risk that a network adapter does become flakey is very small. More typical, the adapters resp. the data connectivity does completely disappear completely, and the UPnP OS does no longer detect the adapter.
Most problems on such NASes are caused by RAID becoming inoperable, due to aged or breaking storage blocks.
Do you have a known working, reliable SATA storage block at hand to set-up the NAS with one single device volume, or two on a RAID 1 volume? Remove the potentially unhealthy storage blocks, and restart a test from scratch.
- tony359Jun 12, 2023Apprentice
Thanks, I'll test next time.
Many have (rightly) recommended a test with a couple of random HDDs. I have plenty so that wouldn't be an issue.
My concern is that sometimes the NAS stays online for weeks without issues and I really cannot keep my data offline for so long.
Is there a way to do an offline test of my drives? Someone recommended booting from a Debian Live-USB but I would need some minor guidance on that. I know how to make the USB, I'm just making sure (as much as possible) I don't do anything that can destroy my data.
Thanks! 🙂
- schumakuJun 12, 2023Guru - Experienced User
Start with retrieving the SMART data from the storage block (aka. disk). Next trigger a full SMART check (rapid, then full) of the storage block. Then retrieve the SMART data again.
You can do this on any platform, without erasing or re-partition or re-format the storage block - if done carefully of course.
- tony359Jun 12, 2023ApprenticeThanks.
I’ll Google how to do that. 🙂
Just to double check: do you mean doing those checks on the NAS itself while it’s online? - StephenBJun 13, 2023Guru - Experienced User
tony359 wrote:
Is there a way to do an offline test of my drives? 🙂
There is an on-line test in the maintenance menu you can use. That runs the full built-in smart test on all the drives in the volume.
You can also use smartctl -x /dev/sda from ssh to see more errors (UNCs in particular) on sda (or whatever disk you wish),
As far as off-line goes, the simplest way is to connect the drive to a Windows PC and run the vendor diag - Dashboard for WDC, and Seatools for Seagate. Unfortunately they don't run on MacOS.
But it seems to me that your symptoms are pointing either to the switch or perhaps the cable going from the NAS to the switch. It's always the NIC port connected to that switch that fails, and the other NIC always continues to work fine.
- tony359Jun 13, 2023Apprentice
Hi Stephen,
No, the ports were swapped last time - also the switch and the cable. So it's not a NIC or Network issue. Well. It ALWAYS fails on that NETWORK so it could be something on my main network. But on this occasion the NAS was wired to the main switch on another port and through an additional switch. So if it's something with that network, it's not a HW issue.
The online maintenance runs periodically. The logs show an "offline" test though. How should I read that? The drive is now 51888hrs.
SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Interrupted (host reset) 90% 50227 - # 2 Extended offline Completed without error 00% 48081 - # 3 Extended offline Completed without error 00% 45875 - # 4 Extended offline Completed without error 00% 43691 - # 5 Extended offline Completed without error 00% 41536 - # 6 Extended offline Completed without error 00% 39834 - # 7 Extended offline Completed without error 00% 37636 - # 8 Extended offline Completed without error 00% 35455 - # 9 Extended offline Completed without error 00% 33273 - #10 Extended offline Completed without error 00% 31118 - #11 Extended offline Completed without error 00% 28912 - #12 Extended offline Completed without error 00% 26707 - #13 Extended offline Completed without error 00% 24525 - #14 Extended offline Completed without error 00% 22554 - #15 Extended offline Completed without error 00% 20712 - #16 Extended offline Completed without error 00% 19182 - #17 Short offline Completed without error 00% 82 - #18 Short offline Completed without error 00% 63 -I ran smartctl -x in the past and posted the output here earlier on this thread. I didn't spot anything but I am not an expert. There are UNC errors on SDA (which I now moved to SDE) but at 7872 hours, a few years ago! 🙂
Error 159 [14] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: WP at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 04 00 00 08 00 00 4b 2b c8 40 40 08 14:59:14.849 WRITE FPDMA QUEUED 60 04 00 00 00 00 00 4b 2b cc 40 40 08 14:59:14.849 READ FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:59:14.849 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:59:14.849 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:59:14.849 IDENTIFY DEVICE Error 158 [13] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: UNC at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 04 00 00 08 00 00 4b 2b cc 40 40 08 14:59:11.031 READ FPDMA QUEUED 61 04 00 00 00 00 00 4b 2b c8 40 40 08 14:59:11.031 WRITE FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:59:11.031 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:59:11.031 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:59:11.030 IDENTIFY DEVICE Error 157 [12] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: WP at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 04 00 00 08 00 00 4b 2b c8 40 40 08 14:59:07.223 WRITE FPDMA QUEUED 60 04 00 00 00 00 00 4b 2b cc 40 40 08 14:59:07.223 READ FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:59:07.223 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:59:07.223 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:59:07.223 IDENTIFY DEVICE Error 156 [11] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: UNC at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 04 00 00 08 00 00 4b 2b cc 40 40 08 14:59:03.405 READ FPDMA QUEUED 61 04 00 00 00 00 00 4b 2b c8 40 40 08 14:59:03.405 WRITE FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:59:03.405 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:59:03.405 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:59:03.405 IDENTIFY DEVICE Error 155 [10] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: WP at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 04 00 00 08 00 00 4b 2b c8 40 40 08 14:58:59.720 WRITE FPDMA QUEUED 60 04 00 00 00 00 00 4b 2b cc 40 40 08 14:58:59.720 READ FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:58:59.720 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:58:59.720 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:58:59.719 IDENTIFY DEVICE Error 154 [9] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b cc 40 40 00 Error: UNC at LBA = 0x4b2bcc40 = 1261161536 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 04 00 00 08 00 00 4b 2b cc 40 40 08 14:58:55.900 READ FPDMA QUEUED 61 04 00 00 00 00 00 4b 2b c8 40 40 08 14:58:55.900 WRITE FPDMA QUEUED ea 00 00 00 00 00 00 00 00 00 00 e0 08 14:58:55.873 FLUSH CACHE EXT 60 00 08 00 08 00 00 00 7f 22 18 40 08 14:58:55.838 READ FPDMA QUEUED 61 00 02 00 00 00 00 00 00 00 48 40 08 14:58:55.838 WRITE FPDMA QUEUED Error 153 [8] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b c8 40 40 00 Error: UNC at LBA = 0x4b2bc840 = 1261160512 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 04 00 00 00 00 00 4b 2b c8 40 40 08 14:58:52.283 READ FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:58:52.283 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:58:52.283 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:58:52.282 IDENTIFY DEVICE ef 00 03 00 46 00 00 00 00 00 00 a0 08 14:58:52.282 SET FEATURES [Set transfer mode] Error 152 [7] occurred at disk power-on lifetime: 7872 hours (328 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 4b 2b c8 40 40 00 Error: UNC at LBA = 0x4b2bc840 = 1261160512 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 04 00 00 00 00 00 4b 2b c8 40 40 08 14:58:48.786 READ FPDMA QUEUED ef 00 10 00 02 00 00 00 00 00 00 a0 08 14:58:48.786 SET FEATURES [Enable SATA feature] 27 00 00 00 00 00 00 00 00 00 00 e0 08 14:58:48.786 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3] ec 00 00 00 00 00 00 00 00 00 00 a0 08 14:58:48.786 IDENTIFY DEVICE ef 00 03 00 46 00 00 00 00 00 00 a0 08 14:58:48.786 SET FEATURES [Set transfer mode]I am Windows so that's fine but wouldn't be better to run the tests on a Linux system so the file system can be checked as well? Also I think I think I'd prefer the disks to stay unmounted so I know I have less chances of damaging the RAID.
Can I start the NAS from a Debian live-USB? I could run the checks from there, assuming VGA works there. And what do you think of that suggestion of running btrfs-check on the drives? I don't dislike the idea of checking the file system.
The NAS disappeared again so I've run dmseg and it's attached (this forum lacks the ability to attach text files!).
Do I see lots of network going down messages after what seems to be a gap? And both ETH0 and ETH1.
Disabling and re-enabling ETH0 worked as usual.
And yes, I've now disabled IPv6 (it got re-enabled when I swapped the IPs I think)
- SandsharkJun 13, 2023Sensei
Yes, you can start a legacy NAS from a Debian Live USB (or even DOS or Windows). Native OS6 models are more picky about what they will start from.
I don't think so. If you needed that, I'd do it in the NAS.
I really don't see how this can be the disks or the file system. If it were, the second NIC wouldn't be responsive when the problem occurs. Plus normal operation wouldn't resume when you set the interface down and then up again.
I think definitely a network issue, though perhaps not the physical layer. The puzzle is what.
Are you using the NAS differently on the main network than you are on the PC connection?
The history here is of course extensive, and I'm have trouble keeping everything straight. Did the NAS ever lock up when it was only connected to the main network (with the PC NIC disconnected)?
The "extended offline" record is actually the test you run from the maintenance settings. No idea why is it described as "offline" by smartctl.
You should also see it at the end of volume.log. It looks like the NAS crashed (or was shut down) before the most recent test finished.
>I really don't see how this can be the disks or the file system. If it were, the second NIC wouldn't be responsive when the >problem occurs. Plus normal operation wouldn't resume when you set the interface down and then up again.
I appreciate your view and I don't disagree with it.
But this has been going on for months and I've tried many things short of a new set of HDDs.
Before I start messing up with my data I'd like to exhaust all the options.
One of them is to do an offline check via Live-CD. As I am not super-skilled with Linux and I care about my data, can someone roughly guide me so I don't obliterate my data 🙂
I guess I'll boot from a Live USB, the 5 RAID HDDs are not going to be mounted by default.
I can then run
btrfs-check --readonly /dev/sd(x)
This should check the file system?
Then smartctl -t long /dev/sd(x)
Anything else anybody can think I should do while the HDDs are offline?
>The history here is of course extensive, and I'm have trouble keeping everything straight. Did the NAS ever lock up >when it was only connected to the main network (with the PC NIC disconnected)?
The PC and the NAS are plugged on the same switch. There is nothing running on the NAS. I only use it as File System.
I appreciate the history is long and I thank you for bearing with me for so long and not suggesting I should go buy a Qnap 🙂
The second NIC connected to the PC is a recent addition as I discovered that when the NAS disappears I can still access it via the other NIC. The behaviour hasn't changed since I also plugged the PC directly into the NAS.
Months ago, the NAS stopped misbehaving when I completely disconnected it from ANY networks.
A week later I plugged it into the PC only (no main network, no internet)
Some weeks of good behaviour later, I put the NAS back on the main network, removing some port forwarding I had in the main router.
It worked PERFECTLY for 2 months.
Then it started disappearing twice a day. Out of the blue.
This is why I am pursuing unlikely routes: the above events point to NOTHING! 🙂
quick addendum:
I've made a live-USB of Debian, played with it and a random HDD which I formatted btrfs.
If anybody has any suggestions on what to test while offline, please do let me know!
Also, if someone has any suggestions on what NOT to do while playing with those HDD, please also do let me know!
You'd need to assemble the RAID array and mount it in order to run btrfs check.
Since your system boots, you can just run ssh (logging in as root), and run btrfs check from there. The device would be /dev/md127 (the raid array virtual disk).
Use --force because the file system is mounted. It won't try to repair anything, so no need to worry about read-only. Don't write anything to the data volume while it is running.
root@RN102:~# btrfs check --force /dev/md127 WARNING: filesystem mounted, continuing because of --force Checking filesystem on /dev/md127 ...You can also run smartctl from ssh (/dev/sda, etc), so need to use the liveCD there either.
root@RN102:~# smartctl --test=long /dev/sda smartctl 6.6 2017-11-05 r4594 [armv7l-linux-4.4.218.armada.1] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION === Sending command: "Execute SMART Extended self-test routine immediately in off-line mode". Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful. Testing has begun. Please wait 127 minutes for test to complete. Test will complete after Tue Jun 13 20:35:03 2023 Use smartctl -X to abort test. root@RN102:~# - tony359Jun 13, 2023Apprentice
Re btrfs I was thinking that exactly - how can the OS check files if they're part of a raid?
But I was under the impression that the disks should be unmounted in order for those checks to be properly done?
I'm referring to this message: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-Pro-6-crashed-again/m-p/2316608/highlight/true#M199637
Also, 126 is the main data volume, should I also check the ones where the OS is stored? I have MD0 (4GB), MD1 (1.3GB), MD127 (1.8TB), MD126 (14.5TB).
- tony359Jun 14, 2023Apprentice
First disk passed long smart succesfully, now onto second one.
Meanwhile the NAS disappeared. I SSH via the second port and I revived it the usual way.
DMESG adds the following from yesterday
[Tue Jun 13 16:14:02 2023] eth1: network connection down [Tue Jun 13 16:14:05 2023] eth1: network connection up using port A [Tue Jun 13 16:14:05 2023] interrupt src: MSI [Tue Jun 13 16:14:05 2023] speed: 10 [Tue Jun 13 16:14:05 2023] autonegotiation: yes [Tue Jun 13 16:14:05 2023] duplex mode: full [Tue Jun 13 16:14:05 2023] flowctrl: none [Tue Jun 13 16:14:05 2023] tcp offload: enabled [Tue Jun 13 16:14:05 2023] scatter-gather: enabled [Tue Jun 13 16:14:05 2023] tx-checksum: enabled [Tue Jun 13 16:14:05 2023] rx-checksum: enabled [Tue Jun 13 16:14:05 2023] rx-polling: enabled [Tue Jun 13 18:08:49 2023] eth1: network connection down [Tue Jun 13 18:08:54 2023] eth1: network connection up using port A [Tue Jun 13 18:08:54 2023] interrupt src: MSI [Tue Jun 13 18:08:54 2023] speed: 1000 [Tue Jun 13 18:08:54 2023] autonegotiation: yes [Tue Jun 13 18:08:54 2023] duplex mode: full [Tue Jun 13 18:08:54 2023] flowctrl: symmetric [Tue Jun 13 18:08:54 2023] role: slave [Tue Jun 13 18:08:54 2023] tcp offload: enabled [Tue Jun 13 18:08:54 2023] scatter-gather: enabled [Tue Jun 13 18:08:54 2023] tx-checksum: enabled [Tue Jun 13 18:08:54 2023] rx-checksum: enabled [Tue Jun 13 18:08:54 2023] rx-polling: enabled [Tue Jun 13 18:55:48 2023] eth1: network connection down [Tue Jun 13 18:55:51 2023] eth1: network connection up using port A [Tue Jun 13 18:55:51 2023] interrupt src: MSI [Tue Jun 13 18:55:51 2023] speed: 10 [Tue Jun 13 18:55:51 2023] autonegotiation: yes [Tue Jun 13 18:55:51 2023] duplex mode: full [Tue Jun 13 18:55:51 2023] flowctrl: none [Tue Jun 13 18:55:51 2023] tcp offload: enabled [Tue Jun 13 18:55:51 2023] scatter-gather: enabled [Tue Jun 13 18:55:51 2023] tx-checksum: enabled [Tue Jun 13 18:55:51 2023] rx-checksum: enabled [Tue Jun 13 18:55:51 2023] rx-polling: enabled [Tue Jun 13 18:55:53 2023] eth1: network connection down [Tue Jun 13 18:55:56 2023] eth1: network connection up using port A [Tue Jun 13 18:55:56 2023] interrupt src: MSI [Tue Jun 13 18:55:56 2023] speed: 1000 [Tue Jun 13 18:55:56 2023] autonegotiation: yes [Tue Jun 13 18:55:56 2023] duplex mode: full [Tue Jun 13 18:55:56 2023] flowctrl: symmetric [Tue Jun 13 18:55:56 2023] role: master [Tue Jun 13 18:55:56 2023] tcp offload: enabled [Tue Jun 13 18:55:56 2023] scatter-gather: enabled [Tue Jun 13 18:55:56 2023] tx-checksum: enabled [Tue Jun 13 18:55:56 2023] rx-checksum: enabled [Tue Jun 13 18:55:56 2023] rx-polling: enabled [Tue Jun 13 18:58:30 2023] eth1: network connection down [Tue Jun 13 18:58:39 2023] eth1: network connection up using port A [Tue Jun 13 18:58:39 2023] interrupt src: MSI [Tue Jun 13 18:58:39 2023] speed: 1000 [Tue Jun 13 18:58:39 2023] autonegotiation: yes [Tue Jun 13 18:58:39 2023] duplex mode: full [Tue Jun 13 18:58:39 2023] flowctrl: symmetric [Tue Jun 13 18:58:39 2023] role: master [Tue Jun 13 18:58:39 2023] tcp offload: enabled [Tue Jun 13 18:58:39 2023] scatter-gather: enabled [Tue Jun 13 18:58:39 2023] tx-checksum: enabled [Tue Jun 13 18:58:39 2023] rx-checksum: enabled [Tue Jun 13 18:58:39 2023] rx-polling: enabled [Tue Jun 13 19:03:51 2023] eth1: network connection down [Tue Jun 13 19:04:50 2023] eth1: network connection up using port A [Tue Jun 13 19:04:50 2023] interrupt src: MSI [Tue Jun 13 19:04:50 2023] speed: 1000 [Tue Jun 13 19:04:50 2023] autonegotiation: yes [Tue Jun 13 19:04:50 2023] duplex mode: full [Tue Jun 13 19:04:50 2023] flowctrl: symmetric [Tue Jun 13 19:04:50 2023] role: slave [Tue Jun 13 19:04:50 2023] tcp offload: enabled [Tue Jun 13 19:04:50 2023] scatter-gather: enabled [Tue Jun 13 19:04:50 2023] tx-checksum: enabled [Tue Jun 13 19:04:50 2023] rx-checksum: enabled [Tue Jun 13 19:04:50 2023] rx-polling: enabled [Tue Jun 13 19:40:18 2023] eth1: network connection down [Tue Jun 13 19:40:20 2023] eth1: network connection up using port A [Tue Jun 13 19:40:20 2023] interrupt src: MSI [Tue Jun 13 19:40:20 2023] speed: 10 [Tue Jun 13 19:40:20 2023] autonegotiation: yes [Tue Jun 13 19:40:20 2023] duplex mode: full [Tue Jun 13 19:40:20 2023] flowctrl: none [Tue Jun 13 19:40:20 2023] tcp offload: enabled [Tue Jun 13 19:40:20 2023] scatter-gather: enabled [Tue Jun 13 19:40:20 2023] tx-checksum: enabled [Tue Jun 13 19:40:20 2023] rx-checksum: enabled [Tue Jun 13 19:40:20 2023] rx-polling: enabled [Tue Jun 13 19:40:23 2023] eth1: network connection down [Tue Jun 13 19:40:26 2023] eth1: network connection up using port A [Tue Jun 13 19:40:26 2023] interrupt src: MSI [Tue Jun 13 19:40:26 2023] speed: 1000 [Tue Jun 13 19:40:26 2023] autonegotiation: yes [Tue Jun 13 19:40:26 2023] duplex mode: full [Tue Jun 13 19:40:26 2023] flowctrl: symmetric [Tue Jun 13 19:40:26 2023] role: master [Tue Jun 13 19:40:26 2023] tcp offload: enabled [Tue Jun 13 19:40:26 2023] scatter-gather: enabled [Tue Jun 13 19:40:26 2023] tx-checksum: enabled [Tue Jun 13 19:40:26 2023] rx-checksum: enabled [Tue Jun 13 19:40:26 2023] rx-polling: enabled [Tue Jun 13 19:41:20 2023] eth1: network connection down [Tue Jun 13 19:41:34 2023] eth1: network connection up using port A [Tue Jun 13 19:41:34 2023] interrupt src: MSI [Tue Jun 13 19:41:34 2023] speed: 1000 [Tue Jun 13 19:41:34 2023] autonegotiation: yes [Tue Jun 13 19:41:34 2023] duplex mode: full [Tue Jun 13 19:41:34 2023] flowctrl: symmetric [Tue Jun 13 19:41:34 2023] role: master [Tue Jun 13 19:41:34 2023] tcp offload: enabled [Tue Jun 13 19:41:34 2023] scatter-gather: enabled [Tue Jun 13 19:41:34 2023] tx-checksum: enabled [Tue Jun 13 19:41:34 2023] rx-checksum: enabled [Tue Jun 13 19:41:34 2023] rx-polling: enabled [Tue Jun 13 20:30:37 2023] eth1: network connection down [Tue Jun 13 20:31:35 2023] eth1: network connection up using port A [Tue Jun 13 20:31:35 2023] interrupt src: MSI [Tue Jun 13 20:31:35 2023] speed: 1000 [Tue Jun 13 20:31:35 2023] autonegotiation: yes [Tue Jun 13 20:31:35 2023] duplex mode: full [Tue Jun 13 20:31:35 2023] flowctrl: symmetric [Tue Jun 13 20:31:35 2023] role: master [Tue Jun 13 20:31:35 2023] tcp offload: enabled [Tue Jun 13 20:31:35 2023] scatter-gather: enabled [Tue Jun 13 20:31:35 2023] tx-checksum: enabled [Tue Jun 13 20:31:35 2023] rx-checksum: enabled [Tue Jun 13 20:31:35 2023] rx-polling: enabled [Tue Jun 13 23:34:51 2023] eth1: network connection down [Tue Jun 13 23:34:54 2023] eth1: network connection up using port A [Tue Jun 13 23:34:54 2023] interrupt src: MSI [Tue Jun 13 23:34:54 2023] speed: 10 [Tue Jun 13 23:34:54 2023] autonegotiation: yes [Tue Jun 13 23:34:54 2023] duplex mode: full [Tue Jun 13 23:34:54 2023] flowctrl: none [Tue Jun 13 23:34:54 2023] tcp offload: enabled [Tue Jun 13 23:34:54 2023] scatter-gather: enabled [Tue Jun 13 23:34:54 2023] tx-checksum: enabled [Tue Jun 13 23:34:54 2023] rx-checksum: enabled [Tue Jun 13 23:34:54 2023] rx-polling: enabled [Tue Jun 13 23:36:26 2023] eth1: network connection down [Wed Jun 14 19:03:49 2023] eth1: network connection up using port A [Wed Jun 14 19:03:49 2023] interrupt src: MSI [Wed Jun 14 19:03:49 2023] speed: 100 [Wed Jun 14 19:03:49 2023] autonegotiation: yes [Wed Jun 14 19:03:49 2023] duplex mode: full [Wed Jun 14 19:03:49 2023] flowctrl: none [Wed Jun 14 19:03:49 2023] tcp offload: enabled [Wed Jun 14 19:03:49 2023] scatter-gather: enabled [Wed Jun 14 19:03:49 2023] tx-checksum: enabled [Wed Jun 14 19:03:49 2023] rx-checksum: enabled [Wed Jun 14 19:03:49 2023] rx-polling: enabled [Wed Jun 14 19:04:48 2023] eth1: network connection down [Wed Jun 14 19:04:51 2023] eth1: network connection up using port A [Wed Jun 14 19:04:51 2023] interrupt src: MSI [Wed Jun 14 19:04:51 2023] speed: 1000 [Wed Jun 14 19:04:51 2023] autonegotiation: yes [Wed Jun 14 19:04:51 2023] duplex mode: full [Wed Jun 14 19:04:51 2023] flowctrl: symmetric [Wed Jun 14 19:04:51 2023] role: slave [Wed Jun 14 19:04:51 2023] tcp offload: enabled [Wed Jun 14 19:04:51 2023] scatter-gather: enabled [Wed Jun 14 19:04:51 2023] tx-checksum: enabled [Wed Jun 14 19:04:51 2023] rx-checksum: enabled [Wed Jun 14 19:04:51 2023] rx-polling: enabled [Wed Jun 14 19:53:22 2023] eth0: network connection down [Wed Jun 14 19:53:32 2023] eth0: network connection up using port A [Wed Jun 14 19:53:32 2023] interrupt src: MSI [Wed Jun 14 19:53:32 2023] speed: 1000 [Wed Jun 14 19:53:32 2023] autonegotiation: yes [Wed Jun 14 19:53:32 2023] duplex mode: full [Wed Jun 14 19:53:32 2023] flowctrl: symmetric [Wed Jun 14 19:53:32 2023] role: slave [Wed Jun 14 19:53:32 2023] tcp offload: enabled [Wed Jun 14 19:53:32 2023] scatter-gather: enabled [Wed Jun 14 19:53:32 2023] tx-checksum: enabled [Wed Jun 14 19:53:32 2023] rx-checksum: enabled [Wed Jun 14 19:53:32 2023] rx-polling: enabledAs you can see, ETH1 seems to go up and down. However, that's the "good" port, the one connected to my desktop. Fair enough, I switched off the computer at night and maybe in the afternoon when I went out. But only twice, not so many times.
Uhm...
- StephenBJun 14, 2023Guru - Experienced User
Interesting that eth1 is also going down.
I am wondering if there is anything else in the logs around Jun 14 19:53:22. I'm thinking that you should check kernel.log, system.log, and systemd-journal.log.
19:53 is me bringing it down via ifconfig.
The interface shows as UP even when it stops responding. When I SSH via ETH1 (the "good NIC") I can ping ETH0's IP but nothing else on that network. All I do is
ifconfig eth0 down
ifconfig eth0 up
and it comes back.
I haven't tested recently but unplugging/replugging the ethernet cable does NOT have the same effect.
I'm thinking of creating a cronjob which turns off and on ETH0 every 12 hours... LOL
Checking logs anyways (the NAS has been disappearing multiple times tonight, every time the NIC trick worked) I see the below in system.log. Is that expected? There is more than that.
Jun 14 01:17:01 Enterprise-NAS CRON[30496]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 01:17:01 Enterprise-NAS CRON[30497]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 01:17:01 Enterprise-NAS CRON[30496]: pam_unix(cron:session): session closed for user root Jun 14 01:40:52 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 01:40:52 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 01:40:52 Enterprise-NAS snapperd[30745]: loading 269 failed Jun 14 01:40:52 Enterprise-NAS snapperd[30745]: loading 270 failed Jun 14 01:40:52 Enterprise-NAS snapperd[30745]: loading 987 failed Jun 14 01:40:52 Enterprise-NAS snapperd[30745]: loading 1032 failed Jun 14 01:40:52 Enterprise-NAS snapperd[30745]: loading 1085 failed Jun 14 02:17:01 Enterprise-NAS CRON[31395]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 02:17:01 Enterprise-NAS CRON[31396]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 02:17:01 Enterprise-NAS CRON[31395]: pam_unix(cron:session): session closed for user root Jun 14 02:40:53 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 02:40:53 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 269 failed Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 270 failed Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 987 failed Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 1032 failed Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 1085 failed Jun 14 03:17:01 Enterprise-NAS CRON[32301]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 03:17:01 Enterprise-NAS CRON[32302]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 03:17:01 Enterprise-NAS CRON[32301]: pam_unix(cron:session): session closed for user root Jun 14 03:40:54 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 03:40:54 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 03:40:54 Enterprise-NAS snapperd[32543]: loading 269 failed Jun 14 03:40:54 Enterprise-NAS snapperd[32543]: loading 270 failed Jun 14 03:40:54 Enterprise-NAS snapperd[32543]: loading 987 failed Jun 14 03:40:54 Enterprise-NAS snapperd[32543]: loading 1032 failed Jun 14 03:40:54 Enterprise-NAS snapperd[32543]: loading 1085 failed Jun 14 04:17:01 Enterprise-NAS CRON[737]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 04:17:01 Enterprise-NAS CRON[738]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 04:17:01 Enterprise-NAS CRON[737]: pam_unix(cron:session): session closed for user root Jun 14 04:40:55 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 04:40:55 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 04:40:55 Enterprise-NAS snapperd[1053]: loading 269 failed Jun 14 04:40:55 Enterprise-NAS snapperd[1053]: loading 270 failed Jun 14 04:40:55 Enterprise-NAS snapperd[1053]: loading 987 failed Jun 14 04:40:55 Enterprise-NAS snapperd[1053]: loading 1032 failed Jun 14 04:40:55 Enterprise-NAS snapperd[1053]: loading 1085 failedSimilar events on systemd-journal.log
Jun 14 15:41:07 Enterprise-NAS snapperd[11245]: loading 269 failed Jun 14 15:41:07 Enterprise-NAS snapperd[11245]: loading 270 failed Jun 14 15:41:07 Enterprise-NAS snapperd[11245]: loading 987 failed Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 15:41:07 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 15:41:07 Enterprise-NAS snapperd[11245]: loading 1032 failed Jun 14 15:41:07 Enterprise-NAS snapperd[11245]: loading 1085 failed Jun 14 16:17:01 Enterprise-NAS CRON[11891]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 16:17:01 Enterprise-NAS CRON[11892]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 16:17:01 Enterprise-NAS CRON[11891]: pam_unix(cron:session): session closed for user root Jun 14 16:41:08 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 16:41:08 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 16:41:08 Enterprise-NAS snapperd[12155]: loading 269 failed Jun 14 16:41:08 Enterprise-NAS snapperd[12155]: loading 270 failed Jun 14 16:41:08 Enterprise-NAS snapperd[12155]: loading 987 failed Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 16:41:08 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 16:41:08 Enterprise-NAS snapperd[12155]: loading 1032 failed Jun 14 16:41:08 Enterprise-NAS snapperd[12155]: loading 1085 failed Jun 14 17:17:01 Enterprise-NAS CRON[12811]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 17:17:01 Enterprise-NAS CRON[12812]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 17:17:01 Enterprise-NAS CRON[12811]: pam_unix(cron:session): session closed for user root Jun 14 17:41:09 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 17:41:09 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 17:41:09 Enterprise-NAS snapperd[13080]: loading 269 failed Jun 14 17:41:09 Enterprise-NAS snapperd[13080]: loading 270 failed Jun 14 17:41:09 Enterprise-NAS snapperd[13080]: loading 987 failed Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 17:41:09 Enterprise-NAS snapperd[13080]: loading 1032 failed Jun 14 17:41:09 Enterprise-NAS snapperd[13080]: loading 1085 failed Jun 14 17:42:11 Enterprise-NAS sshd[11072]: pam_unix(sshd:session): session closed for user root Jun 14 18:17:01 Enterprise-NAS CRON[13730]: pam_unix(cron:session): session opened for user root by (uid=0) Jun 14 18:17:01 Enterprise-NAS CRON[13731]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jun 14 18:17:01 Enterprise-NAS CRON[13730]: pam_unix(cron:session): session closed for user root Jun 14 18:41:10 Enterprise-NAS dbus[2876]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Jun 14 18:41:10 Enterprise-NAS dbus[2876]: [system] Successfully activated service 'org.opensuse.Snapper' Jun 14 18:41:10 Enterprise-NAS snapperd[13989]: loading 269 failed Jun 14 18:41:10 Enterprise-NAS snapperd[13989]: loading 270 failed Jun 14 18:41:10 Enterprise-NAS snapperd[13989]: loading 987 failed Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is empty Jun 14 18:41:10 Enterprise-NAS org.opensuse.Snapper[2876]: ^ Jun 14 18:41:10 Enterprise-NAS snapperd[13989]: loading 1032 failed Jun 14 18:41:10 Enterprise-NAS snapperd[13989]: loading 1085 failed - StephenBJun 14, 2023Guru - Experienced User
Are you using FlexRAID or X-RAID?
Can you post a mdstat.log from the log zip file?
MD0 is the OS partition; MD1 is swap (and just raw storage, not BTRFS).
tony359 wrote:But I was under the impression that the disks should be unmounted in order for those checks to be properly done?
BTRFS check should work with the volume mounted if there are no disk writes being made to the volume.
I don't recommend doing that for MD0, and and you can't unmount it.
If you want to attempt a repair, you could unmount the data volume (or if necessary, reboot in tech support mode, and manually assemble the RAID. Alternatively, destroy the volume and recreate from the web ui.
mdadm (software RAID) creates virtual disk(s), and BTRFS is layered on top of those disks.
Jun 14 02:40:53 Enterprise-NAS snapperd[31638]: loading 1085 failedThese are failures to load snapshots, so it does look like something might be happening with the file system. But I don't think it's related to the crash.
Somehow I missed that. Probably a clue on what's going on, but I am not sure how to interpret it.
Are you using DHCP for eth0? Or is there a static IP address configured on the NAS?
- tony359Jun 15, 2023Apprentice
How do you quote on this forum? 🙂
The "quote" feature quotes the whole message and I haven't figured out a way to "break" the quote line to insert my comments!
> Are you using FlexRAID or X-RAID? Can you post a mdstat.log from the log zip file?
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md126 : active raid5 sde3[0] sda3[4] sdd3[3] sdc3[2] sdb3[1] 15608675328 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/5] [UUUUU] md127 : active raid1 sdd4[0] sda4[1] 1953371904 blocks super 1.2 [2/2] [UU] md1 : active raid10 sde2[0] sda2[4] sdd2[3] sdc2[2] sdb2[1] 1305600 blocks super 1.2 512K chunks 2 near-copies [5/5] [UUUUU] md0 : active raid1 sde1[0] sda1[4] sdd1[3] sdc1[2] sdb1[1] 4190208 blocks super 1.2 [5/5] [UUUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Sun Aug 26 00:34:51 2018 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 5 Total Devices : 5 Persistence : Superblock is persistent Update Time : Wed Jun 14 19:53:56 2023 State : clean Active Devices : 5 Working Devices : 5 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 33ea1503:0 (local to host 33ea1503) UUID : a3f67404:2cd8011d:09213554:fc037d7f Events : 484 Number Major Minor RaidDevice State 0 8 65 0 active sync /dev/sde1 1 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 4 8 1 4 active sync /dev/sda1 /dev/md/1: Version : 1.2 Creation Time : Wed Oct 28 18:16:31 2020 Raid Level : raid10 Array Size : 1305600 (1275.00 MiB 1336.93 MB) Used Dev Size : 522240 (510.00 MiB 534.77 MB) Raid Devices : 5 Total Devices : 5 Persistence : Superblock is persistent Update Time : Wed Mar 29 01:00:17 2023 State : clean Active Devices : 5 Working Devices : 5 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Consistency Policy : unknown Name : 33ea1503:1 (local to host 33ea1503) UUID : e1dc0162:09789205:30db0ea7:1cbe88d0 Events : 19 Number Major Minor RaidDevice State 0 8 66 0 active sync /dev/sde2 1 8 18 1 active sync /dev/sdb2 2 8 34 2 active sync /dev/sdc2 3 8 50 3 active sync /dev/sdd2 4 8 2 4 active sync /dev/sda2 /dev/md/data-0: Version : 1.2 Creation Time : Sun Aug 26 00:35:10 2018 Raid Level : raid5 Array Size : 15608675328 (14885.59 GiB 15983.28 GB) Used Dev Size : 3902168832 (3721.40 GiB 3995.82 GB) Raid Devices : 5 Total Devices : 5 Persistence : Superblock is persistent Update Time : Wed Jun 14 19:11:02 2023 State : clean Active Devices : 5 Working Devices : 5 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Name : 33ea1503:data-0 (local to host 33ea1503) UUID : d6f2d4fc:a4ed5491:5e974d0e:f44619ef Events : 7339 Number Major Minor RaidDevice State 0 8 67 0 active sync /dev/sde3 1 8 19 1 active sync /dev/sdb3 2 8 35 2 active sync /dev/sdc3 3 8 51 3 active sync /dev/sdd3 4 8 3 4 active sync /dev/sda3 /dev/md/data-1: Version : 1.2 Creation Time : Wed Oct 28 18:16:34 2020 Raid Level : raid1 Array Size : 1953371904 (1862.88 GiB 2000.25 GB) Used Dev Size : 1953371904 (1862.88 GiB 2000.25 GB) Raid Devices : 2 Total Devices : 2 Persistence : Superblock is persistent Update Time : Wed Jun 14 19:11:02 2023 State : clean Active Devices : 2 Working Devices : 2 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 33ea1503:data-1 (local to host 33ea1503) UUID : 1114a09f:c1c52914:f69c2626:a1a5ff09 Events : 71 Number Major Minor RaidDevice State 0 8 52 0 active sync /dev/sdd4 1 8 4 1 active sync /dev/sda4>BTRFS check should work with the volume mounted if there are no disk writes being made to the volume.
> If you want to attempt a repair, you could unmount the data volume (or if necessary, reboot in tech support mode, and > manually assemble the RAID. Alternatively, destroy the volume and recreate from the web ui.
Well I cannot be 100% sure there won't be disk writes being done.
I thought that checking the OS partition was the key - again see the message linked above which maybe is misleading?
Destroy and re-create the volume? How?
Why wouldn't you recommend a btrfs-check on MD0? Not questioning, just curious.
Maybe. But I think every time I found the NAS unresponsive, when I went to the log page to save logs I saw snapshots being deleted as last entries - on the UI logs. Probably a coincidence but...
Nah, it's just that this has been going on forever! 🙂
There is a DHCP indeed but the NAS is set to static. The IP address I am using is outside of the DHCP pool.
- StephenBJun 15, 2023Guru - Experienced User
tony359 wrote:How do you quote on this forum?
Once you have the full quote, you can edit out the parts you don't want. Though it can be quirky - you can't quote the code inserts (</>) at all for some reason, and sometimes it is hard to position the cursor. Also, sometimes bugs in the forum software result in messed up markup text, which give you errors when you post. I switch into html mode when I run into those problems, and manually fix things up.
Simplifying mdstat shows this:
/dev/md/data-0: Version : 1.2 Creation Time : Sun Aug 26 00:35:10 2018 Raid Level : raid5 Array Size : 15608675328 (14885.59 GiB 15983.28 GB) Number Major Minor RaidDevice State 0 8 67 0 active sync /dev/sde3 1 8 19 1 active sync /dev/sdb3 2 8 35 2 active sync /dev/sdc3 3 8 51 3 active sync /dev/sdd3 4 8 3 4 active sync /dev/sda3 /dev/md/data-1: Version : 1.2 Creation Time : Wed Oct 28 18:16:34 2020 Raid Level : raid1 Array Size : 1953371904 (1862.88 GiB 2000.25 GB) Number Major Minor RaidDevice State 0 8 52 0 active sync /dev/sdd4 1 8 4 1 active sync /dev/sda4This would be XRAID, since there is vertical expansion of two disks - sda, and sdd. There are two RAID groups data-0 and data-1.
Data-0 (md126) was created first (back in 2018), and shows that you originally had a 5x4TB array. Data-1 (md127) was created in Oct 2020, when you expanded by replacing sda and sdd with 6 TB drives. You can see that the NAS created additional partitions on these disks (sda4 and sdd4), and created a RAID-1 array on the additional space.
These two groups are concatenated by BTRFS into a single data volume.
FWIW, back in 2018, Data-0 was md127. When you expanded, data-1 became md127, and data-0 became 126.
Though I haven't tested the BTRFS commands extensively, I believe checking md127 will test the entire concatenated volume. You can also try checking md126 if you want - since there is no repair, it is safe.
While you can't be certain on the data volume, the risk would be that btrfs check would give you spurious errors (since there is no repair happening). You can minimize that risk by disconnecting eth0. You could also try umount /data and then run the test. The NAS could log spurious errors when readynasd tries to access the unmounted volume, so you'd need to ignore those. Since the volume wouldn't be mounted, you could add the --repair option to the check. When done, it'd be best to reboot the NAS.
As far as the OS partition goes, linux is installed on that partition. Odds of writes happening during the check are much higher. You can check md0 off-line by rebooting the NAS in tech support mode. You'd manually assemble md0, and not mount it. Linux would be running off the boot flash, so as long as btrfs is fully installed there (which it should be), you can run the check.
The repair attempt is risky, so it is important to have a full backup before you try it. Obviously destroying the volume would also require a full backup.
These errors
Jun 14 17:41:09 Enterprise-NAS org.opensuse.Snapper[2876]: :1: parser error : Document is emptydo suggest something isn't quite right on the OS partition. The failure to load the snapshots also could be related to a mildly corrupted config stored on the OS partition.
That doesn't necessarily mean that BTRFS file system for the OS is corrupted - something else might have gone wrong over the years. And repairing the file system itself likely wouldn't repair the config files - it would just repair (or delete) internally inconsistent structures.
The brute-force path is to do a factory default from the system settings page (or from the boot menu). This re-formats the disks, and does a fresh OS install from the boot flash. You'd then need to reconfigure the NAS and reinstall any apps, and restore the files from backup.
It is possible to save/restore the config to speed things up a bit, but since we know something is wrong with the snapshot setup, I don't recommend doing that.
You can also destroy the data volume by right-clicking the settings wheel on the volumes page, and choosing destroy. Then select the disk from the center, and create a new one. Uninstall apps first (as they are installed to the data volume). When the new volume is created, you'd need to reconfigure the shares, reinstall apps, and recreate any backup jobs.
Since the default rebuilds everything, it is probably a good next step. It would give you confidence that the configuration and file systems are all completely clean. Any other path will lead you to wonder if you missed something.
- tony359Jun 16, 2023Apprentice
Ok so you manually go into HTML and add </blockquote> and <blockquote> when needed? What I cannot figure out is how to BREAK the quote to add my comment.
I did this manually on the HTML page but it's very messy and time consuming 🙂
I started with 2x4TB. Then added another 4TB Then added a 6TB Then added a 6TB
thanks
Thanks for all the other advice - I just got lost in the HTML page so I'm adding a master comment here 🙂
I'll complete the SMART tests then I'll start doing some FS tests.
Regarding wiping the OS partition, yes, it's the nuclear option which was brought up several times over the months.
I appreciate it's a good option but as I said it would mean transferring 12TB of data.
My desktop has a 24port RAID card, I can pile up some HDDs I have around, make a BORG ship by my computer with power supplies, cables and drives and transfer everything there while I hit the red button on the NAS.
It's just that
1. I'd rather not do that 🙂
2. it's a linux PC, I'm sure there is a way to fix it without wiping it (and I am in NO WAY questioning anybody's help or skills here, just moaning aloud!)
3. I have a feeling there is a good chance that I spend a week wiping the NAS and then the same issue happens again. 🙂
As the NAS seems to be in a state where it disappears every few hours, I **could** try replacing the HDDs with a couple random HDDs and factory reset for a test. But as I said, the NAS would work for 2 months without glitches in the past so I feel that that would also be an inconclusive test.
Oh my. 🙂
- StephenBJun 16, 2023Guru - Experienced User
I only use html mode if something goes wrong. As I tried to say, normally I just add my comments at the bottom of the full quote, and then remove the parts of the quote I don't want. So I'm not "breaking" the quote. I'm quoting multiple times, and removing text as I go.
One general comment - RAID isn't enough to keep your data safe. So you should have a backup anyway.
tony359 wrote:
It's just that
Well, you've been chasing this problem for a long time, and we still don't know the cause.
So it is possible that you'll spend a few days rebuilding the NAS, and still not solve the problem. But
- Offloading and restoring the data is largely unattended, so not a huge burden on your time.
- BTRFS repair is frankly dangerous, you can easily end up with data loss (or an unbootable NAS). So you need to offload data either way.
- Even if the problem still happens, you will have ruled out corruption of the NAS software/file system - which is progress. If your repair attempts don't work, then you'll never know if there is a repair needed that you missed.
StephenB wrote:
tony359 wrote:Ok so you manually go into HTML and add </blockquote> and <blockquote> when needed? What I cannot figure out is how to BREAK the quote to add my comment.
The clunkiest forum ever 😄 Sorry! 🙂
But thanks. Better than nothing!
tony359 wrote:I appreciate it's a good option but as I said it would mean transferring 12TB of data.
All my data is backed up somewhere. Some is online. iDrive is not the best service available when it comes to restore data and my broadband is "only" 100Mbit.
Restoring from online means lots of time.
The rest is on local HDDs. Doable but would take lots of time anyways.
Most of that time is unattended - but a hassle nevertheless.
I 100% see your point on the rest (I'm already tired of quoting and deleting LOL). A fresh start is a fresh start. Most importantly it would rule out the SW straight away.
I'll think about the Borg ship.
- tony359Jun 18, 2023Apprentice
SMART longs tests came up clean on all drives.
BTRSFS check did not. The below is MD127
root@Enterprise-NAS:~# btrfs check --force /dev/md127 WARNING: filesystem mounted, continuing because of --force Checking filesystem on /dev/md127 UUID: 256f20f5-bce4-4561-91a8-f5efb92f82fe checking extents checking free space cache checking fs roots root 17467 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17495 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17894 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17919 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17952 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17962 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17981 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 18045 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 18148 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 ERROR: errors found in fs roots found 13917869395968 bytes used, error(s) found total csum bytes: 501016 total tree bytes: 1743912960 total fs tree bytes: 1651933184 total extent tree bytes: 85065728 btree space waste bytes: 341607782 file data blocks allocated: 43039469133824 referenced 32223623094272...continued
This is MD126
root@Enterprise-NAS:~# btrfs check --force /dev/md126 WARNING: filesystem mounted, continuing because of --force Checking filesystem on /dev/md126 UUID: 256f20f5-bce4-4561-91a8-f5efb92f82fe checking extents checking free space cache checking fs roots root 17467 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17495 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17894 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17919 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17952 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17962 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 17981 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 18045 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 root 18148 inode 1177157 errors 100, file extent discount Found file extent holes: start: 4915200, len: 40960 start: 4980736, len: 36864 start: 5103616, len: 65536 start: 5242880, len: 65536 start: 5365760, len: 45056 start: 5439488, len: 53248 start: 5509120, len: 40960 start: 5570560, len: 28672 start: 5701632, len: 57344 start: 5763072, len: 61440 start: 5828608, len: 65536 start: 5902336, len: 61440 start: 6025216, len: 118784 start: 6156288, len: 12288 start: 6217728, len: 28672 start: 6287360, len: 45056 start: 6356992, len: 16384 start: 6426624, len: 8192 start: 6483968, len: 20480 start: 6557696, len: 24576 start: 6623232, len: 32768 start: 6680576, len: 61440 start: 6750208, len: 20480 start: 6815744, len: 40960 start: 6881280, len: 24576 start: 6938624, len: 57344 start: 7012352, len: 135168 start: 7200768, len: 53248 start: 7274496, len: 53248 start: 7405568, len: 57344 start: 7471104, len: 45056 start: 7598080, len: 61440 start: 7729152, len: 40960 start: 7790592, len: 32768 start: 7921664, len: 28672 start: 7983104, len: 49152 start: 8060928, len: 36864 start: 8183808, len: 32768 start: 8253440, len: 53248 start: 8323072, len: 49152 start: 8388608, len: 16384 start: 8454144, len: 49152 start: 8519680, len: 16384 start: 8585216, len: 40960 start: 8642560, len: 61440 start: 8716288, len: 12288 start: 8781824, len: 20480 start: 8843264, len: 49152 start: 8904704, len: 61440 start: 9043968, len: 73728 start: 9166848, len: 53248 start: 9232384, len: 73728 start: 9367552, len: 24576 start: 9424896, len: 36864 start: 9572352, len: 40960 start: 9625600, len: 36864 start: 9695232, len: 65536 start: 9830400, len: 94208 ERROR: errors found in fs roots found 13917869395968 bytes used, error(s) found total csum bytes: 501016 total tree bytes: 1743912960 total fs tree bytes: 1651933184 total extent tree bytes: 85065728 btree space waste bytes: 341607782 file data blocks allocated: 43039469133824 referenced 32223623094272 - tony359Jun 18, 2023Apprentice
(Sorry for splitting the message in three but there is a 20K limit per message and I cannot attach TXT files)
What do I learn from this?
I have now ordered the required cables to mount a bunch of HDDs onto my Desktop RAID card, I will transfer everything soon and I will reset the NAS. I give up 🙂
(That said, it's been behaving well recently, again!!)
Oh, one little gossip on the PSU: I think I am responsible for the swollen caps! When I replaced the fan, I powered it from the PSU itself. It's a noctua so little airflow. I noticed the PSU powers it at 5V (it's a 12V fan, unless I made a mistake and the original fan was 5V?).
So the bottom line is: i baked that PSU 100%. I tested it a bit and those heatsinks were scorcing hot while running. I re-wired the fan so it's going to be powered from 12V somewhere else.
Only thing I am going to do differently is to reverse the airflow: I know it's supposed to pull air IN, but I don't agree with that. I think pushing air OUT is a better option as as it stands the PSU is pulling in the hot air expelled from the main fan.
- schumakuJun 18, 2023Guru - Experienced User
What do I learn from this?.
The added value of these logs is over-estimated. Nothing we can take out of the full logs here.
A bunch of popular mistakes combined. No that people sometimes don't read voltage specs - much more the **** idea replacing stock fans by Noctua fans (very popular, must be a good choice because of hey, these are soooo silent). These are silent, because of the rpm is lower than the usual high-speed fans (in the 10'000 ... 15'000 RPM range sometimes), and the air flow and the air pressure generated is just a fraction of what is intended by the hardware designers, and required to keep the internals reasonable cool.
