budda1
Mar 03, 2018Aspirant
ReadyNAS Pro 6 has become unstable and regularly hangs
My ReadyNAS Pro has started hanging after running fine for many years. Currently running firmware 6.9.2 but have had the same problem with the last few versions released. I've tried disablin...
budda1
Thanks for the pointers Stephen.
volume.log shows all disk SMART info as passed/healthy, and no errors or retry counts for any of the disks. I don't claim to understand what most of the info in the volume.log is about.
I'm using RAID5 if that is of importance, using 4 disks.
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 717M 3.0G 20% /
Mar 03, 2018Guru - Experienced User
What services do you have enabled?
- budda1Mar 03, 2018Aspirant
- Running (green light) services are SMB, AFP, UPnP, SSH, HTTPS, HTTP
Other info may be of use...
- Apps i have Plex, CouchPotato, Sickbeard, uTorrent. I've also turned them all off to rule them out, and the ReadyNAS has still done the same freezing after a few days/week.
- I have no backups configured.
- Bonded network carts on round-robin.
- All shares have snapshot turned off as I first thought that might be triggering it.
- CPU running at an average 43 C
- StephenBMar 04, 2018Guru - Experienced User
Do you have a static LAG set up on the switch? Round-robin requires that.
- budda1Mar 04, 2018Aspirant
No, I've not got LAG configured on the switch ports.
Thinking about it -- around the time this ReadyNAS issue probably started happening Netgear factory reset the GS748Tv5 switch whilst we were trying to diagnose a different problem last year.
So I've added the two switch ports the ReadyNAS is plugged in to on the LAG table:
Could this be a reason for the ReadyNAS locking up randomly after a few days?
