joel_smith
Apr 28, 2021Tutor
Orbi RBR50 Dropping Internet Connection Regularly
Hi,
I have an RBR50 (V2.7.2.104) and two satellites - RBS20 (V2.6.2.104), RBS50 (V2.7.2.104) - in my mesh. The router is connected to the NBN Connection Box: Arris CM8200B
Close to every 2 and half minutes, 5-7 packets get dropped and the connection drops out (see Pingplotter graphs below). Most applications can cope, but it is wreaking havoc with VOIP applications e.g. Teams & Skype. The frequency is suspciously close to the DHCP Lease renewal in the Admin portal - Advanced > Internet Port > Connection Status.
6 HOURS
30 MINUTES
What is the size of your home? ~300m2
What is the distance between the router and satellite(s)?
RBR50 is located downstairs at the front of the house - Ethernet to switch > NBN Connection Box
RBR50 > RBS20 - upstairs front - Wireless backhaul ~5m
RBR50 > RBS50 - downstairs rear - Ethernet backhaul via switch ~10 metres
What channels are you using? 2.4Ghz is auto, currently Channel 1. 5Ghz Channel 36
Any Wifi Neighbors near by? If so, how many? Generally 3 nearby SSIDs
I have read the following threads without a solution:
- Re: Orbi RBR50 Dropping Internet Connection Regularly
- Re: Another RBR50 Dropping Internet Connection
- Orbi disconnects after ip change
The DHCP Advanced > Internet Port > Connection Status
- Lease Obtained 0 Days, 0 Hours, 5 Minutes
- Lease Expires 0 Days, 0 Hours, 3 Minutes
If I telnet - root@RBR50:/# config get wan_lease, I get 86400 as the response. Setting the wan_lease to another value didn't appear to make any difference to the packet loss, or the Connection Status values.
I don't understand where the Connection Status values are coming from?
OTHER INVESTIGATIONS
- RBR50 ethernet direct to NBN Connection Box & wifi to laptop ie. no switch - dropped packets issue persists
- Laptop ethernet direct to to NBN Connection Box - no dropped packets
- ISP modem ethernet to NBN Connection Box & wifi to laptop - no dropped packets
I am at a loss as to what else I can do to troubleshoot and hopefully rectify. Hoping someone has some advice.
Cheers, Joel
Arggh, I thought I had it with the DNS settings. Apparently not.
But today I have put the ISP modem into faux-bridge mode & connected the Orbi RBR50 to that, so far so good just need to tidy up the network rack now! Below is what I ended up with.
joel_smith wrote:Close to every 2 and half minutes, 5-7 packets get dropped and the connection drops out (see Pingplotter graphs below). Most applications can cope, but it is wreaking havoc with VOIP applications e.g. Teams & Skype. The frequency is suspciously close to the DHCP Lease renewal in the Admin portal - Advanced > Internet Port > Connection Status.
- Lease Expires 0 Days, 0 Hours, 3 MinutesIf I telnet - root@RBR50:/# config get wan_lease, I get 86400 as the response. Setting the wan_lease to another value didn't appear to make any difference to the packet loss, or the Connection Status values.
It is really frustrating that the community forum does not display images that are created "in-line" with the "Photos" icon on the menu bar do not appear until approved by a forum moderator (which can take hours...or days), while images that are attached with the Browse button (lower left) appear at attachments immediately.
An IP lease of 5 minutes is insane. This is the kind of thing network administrators do when they are preparing to make some drastic change to their network architecture. I would call the ISP and ask, "what the F**K are you guys doing to me?"
Please attach the images so we can see them.
Thanks
Thanks CrimpOn for the validation that the lease time is whack. That said, I thought the Orbi should be bale to handle the lease renewal without complaint???
And also saving my sanity as I tried to find a work around to upload the images.
Attached is the 6 houview of the pingplotter graph.
CrimpOn wrote:An IP lease of 5 minutes is insane. This is the kind of thing network administrators do when they are preparing to make some drastic change to their network architecture. I would call the ISP and ask, "what the F**K are you guys doing to me?"
Following your adive, I contacted the ISP, they completed a line test & apparently found a problem, it is being escalated. Not sure it all adds up for me, but fingers crossed.
